07-08-2018, 04:26 PM | #1 |
Rep 4
run flat tire pressure
Can anyone help me with the recommended tire pressures, my handbook implies there should be instructions on the edge of the driver door but there's nothing there.
I have a 540i xDrive M Sport with the 245/35R20 95Y on the front and 275/30R20 97Y on the rear. The idrive is telling me the front left one is low at 37 but the others are green at 38. I'm not sure what to inflate them to. Thanks |
07-08-2018, 04:48 PM | #2 | |
499
Rep 987
Drives: G30 - 530d M Sport
I'll take a picture of mine tomorrow and post it if you haven't got it. |
07-08-2018, 09:43 PM | #4 |
204
Rep 247
Drives: BMW M3 Comp Xdrive
I have the same tires and my door states 36 front 44 rear
07-08-2018, 11:29 PM | #5 | |
113
Rep 51
07-09-2018, 12:40 AM | #6 |
85
Rep 375
Idrive tells you both current and recommended pressure for each tyre.
Just make sure you select the correct wheel/tyre sizes you are running.
G30 540i xDrive M Sport MPPSK / BM3 |
07-09-2018, 06:33 AM | #8 |
Rep 4
Thanks guys, the iDrive is set to "other" under tire type as the ones I have don't appear to be an option. I guess I'll set them to 36/44 cold and perform a reset on the iDrive.
07-09-2018, 12:29 PM | #10 |
Rep 4
Ah yeah you're right. Well I set it to those tires and it recommended 38psi for all 4. Although that's quite different to the sticker suggesting 36/44. Strange
07-09-2018, 03:33 PM | #11 |
499
Rep 987
Here's my sticker as promised. I suggest you go for 35/38 if you only have 2-3 people.
07-10-2018, 12:41 AM | #13 |
2702
Rep 5,023
Interesting. Must admit I've only looked at idrive rather than that sticker.
Will have to have a look as I might be running higher pressures than necessary , ( will idrive flag that if I lower a bit? mmmm) |
07-10-2018, 02:22 AM | #14 |
499
Rep 987
I don't think so. My understanding is that once you reset the system with lower pressure, it'll simply monitor the new circumstances.
