Adding USB to E91 (2011)
07-06-2018, 12:45 PM | #1 |
Rep 9
Hi All
I have a friend of a friend who's asked me to do him a favour and code USB to his 2011 E91 320d (UK). I've looked up his VIN and he has the following equipment as standard that seemed relevant.
He's also purchased a USB/Aux adaptor and cable (pictured below) before I was asked to help with the coding. With what he has standard and what he's bought, is this a simple VO/coding job? If so, what do I need to add to the VO, etc to get this working? Any assistance is very much appreciated. I've done a little basic coding, but this one is new for me.
/// 2011 E82 135i 6MT ///
07-06-2018, 01:51 PM | #2 |
458
Rep 2,754
you need to check if he has module in the trunk under cental cover, behind backrest
after that you can code 6FL option to headunit and that module
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
07-06-2018, 04:24 PM | #3 |
Rep 9
Thank you for your answer. Do you know what the module is called? I'm going to have to describe it to him as he's a little way from me.
07-06-2018, 09:06 PM | #4 |
1915
Rep 13,107
Has to be a Mulf 2 hi or combox for usb.
Any coder that knows what he is doing will know this. You may need an icom a cable for the coding to work on this. |
07-07-2018, 08:09 AM | #5 |
398
Rep 1,579
Long shot. Pull the radio and see if the radio has a plug for the USB cable shown above. I have seen a few European radios that had built in USB.
If not, I assume there is no i-drive so you can't go combox. Mulf2 HI could be added to the trunk using the TCU pre-wiring. Just snip of the plastic blocking it from plugging it in. You will need to also run aux wiring into the MULF. I would just leave the USB in the trunk and use a tune2air for BT audio. The USB wire above is not long enough to go from arm rest to trunk. Mulf can also support BT phone if you add the mic and bt antenna. https://www.amazon.com/Bovee-WMA3000...s=bmw+tune2air |
07-07-2018, 08:19 AM | #6 |
458
Rep 2,754
simply ask him to make a photo of the module in trunk under cover, behind backrest
07-07-2018, 04:57 PM | #7 |
Rep 9
Thanks for the help so far, I'll get a photo of what's under the cover in the boot (sorry, trunk for my American friends).
