(slotted) Brembo Sport Rotor Part Nos for 06 330i (and others)
06-25-2018, 09:15 PM | #1 |
Rep 6
I've noticed that the Brembo Sport Rotors are available for this car at an often reasonable price (sometimes from ebay) due to many of them being discontinued, much like the performance exhaust recently. These are quality zinc coated rotors with a slight gold tint (obviously it wears off from the braking surface).
I had found that there are not many slotted only offerings on the market designed for stock calipers and that many are from random ebay brands with unknown track records (Centric does have sport slotted which are probably decent) or more expensive offerings like from EBC, which seem priced high enough that you might consider a big brake kit instead Also the record before getting these I happily ran Centric CTEK blanks from Rockauto purchased for a pittance for years. I only replaced them after getting a slight shimmy upon braking and some squeal from my ceramic pads after years and figured I'd replace everything since I was unhappy with ceramic pad braking performance and wanted zinc coated rotors. They are sold as pairs in a single box. 2006 330i Brembo Sport Slotted Front: 33S60200 (330 x 24mm) - I think there is an ebay seller selling these for less than 150 a pair 2006 330i Brembo Sport Slotted Rear: 33S60214 (336 x 22mm) 330xi part numbers are the same according to the brembo catalog. If you are looking for drilled rotors, the numbers are 33S50200 and 33S50214. For most 335i E90 models, the rears are the same as the 330i. The fronts are 33S60204. If you have an LCI please confirm w/brembo catalog. For other models, please check the brembo catalog: http://www2.brembo.com/en/News/Docum...%20crocini.pdf Last edited by go_threethirty_go; 06-25-2018 at 09:24 PM.. |
