Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Eibach Pro Feedback please
      06-22-2018, 11:46 PM   #1
mawzi
20
Drives: 2012 335is MT
Hi guys, my car is an e92 335is.
I recently went from sport oem suspension to eibach pro + Koni yellows. The Konis are 1 turn from soft in the back, and 1.5 turns in the front.
The problem is I still feel that the car is a little floaty. Since I already bought the shocks, it doesn't make sense to get coilovers at this point.
Are there any springs I can get to get a better feel? Should I try to stiffen the shocks more?
H&R are too low for me. Was thinking about BMW performance springs, but they seem to keep the gap in the front.
I'm planning on getting an LSD soon, and I'm afraid the eibachs might become a weak link.
Thoughts?
      06-23-2018, 11:15 AM   #2
boosthead
40
Drives: 2009 328ix
The floatiness comes from the damping. Try adjusting the shocks. I don't have experience with the Konis on the e90 but had them on a number of other cars and they were great. Unfortunately, I had an issue dialing them in on my wife's car and ended up replacing them with FSD's.
      06-25-2018, 01:34 PM   #3
WatchWolf34
Because Racecar
126
Drives: 2009 E90 335i 6MT
I have the same feeling. Installed my Koni Yellows + Eibach last night. I put the front to the stiffest setting and the rears are neutral. Felt a bit floaty in the rear so I am going to stiffen those to the most aggressive as well.
      06-25-2018, 03:33 PM   #4
SnapCoupe
BMW Portland
224
Drives: Z4M Coupe/E90 335i
Thoughts?
I'm looking into this setup and am worried it will still be too soft/floaty for my taste considering the spring rates of the pro kit are very similar to ZSP.
Try stiffening the shocks a bit more and check back. I have read that 60-80% is the sweet spot for the Koni yellows with lowering springs. If the floatiness is mainly in the rear and you can feel it mainly under throttle, look into rear subframe bushings/inserts.
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
      06-25-2018, 04:53 PM   #5
mawzi
20
Let me know how it goes. I'm thinking I should have gone with the BMW Performance springs or the Dinan.
      06-25-2018, 04:55 PM   #6
mawzi
20
Anyone has Eibachs and LSD installed?
      06-28-2018, 12:23 PM   #7
mawzi
20
Originally Posted by chris@strutmonkey View Post
Remember that brand new springs need time to settle. It is similar to brand new tires. I would give it some time before overreacting.
It's been two weeks. Anyways, I got the Dinan springs. I'll put them on to see if I like them.
      06-28-2018, 03:03 PM   #8
SnapCoupe
BMW Portland
224
Have you tried stiffening the shocks yet?
      06-28-2018, 07:22 PM   #9
mawzi
20
I haven't. I might try that first.
      07-08-2018, 08:36 PM   #10
Rob09msport
128
Drives: 09 335 msport
Rear spring pad and shock mount are weak links monroe makes a shick mount that is rubber and like the dinan bit only 12 dollars instead of hundred
      07-09-2018, 09:41 AM   #11
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
2214
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
907984
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      07-11-2018, 04:53 PM   #12
whyzee125
1679
Drives: Dinan stage 2 335i
I chose my springs based on spring rates and used e30 front perches and pads to adjust height. I'm happy with my setup
      07-11-2018, 04:54 PM   #13
whyzee125
1679
Some springs to cinsifer could be swift r spec, Dinan, BMWPS, h&r sport with e30 perches. Good luck.
