06-22-2018, 01:44 AM | #1 |
Rep 8
Mid speaker depth
I'm about to purchase an M235i and was curious if anyone has measured the 4" speaker depth and/or also knows the maximum spacer size.
I've searched and have only found answers recommending speaker sets - unfortunately, none of them publish dimensions. Even if you've installed a mid from a manufacturer that publishes dimensions that would help a great deal. Appreciated. |
06-26-2018, 05:04 PM | #2 | |
1753
Rep 2,942
On the back deck, depth is not an issue.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
06-26-2018, 06:08 PM | #3 |
4517
Rep 8,942
Coupe yes, convertible no. I haven't measured but I'd guess it's about the same as the doors. OP if you've got a vert you've got one more thing to worry about.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-26-2018, 11:57 PM | #4 | |
Rep 8
I was looking through this thread where the OP installed the Focal ISC100: http://www.2addicts.com/forums/showthread.php?t=1495377 The claimed (bottom mount) depth by Focal is 49mm. I can't see the spacer that the OP used as having not very much thickness at all. What drivers have you ran or tried in the door position? I have about eight to ten 4" drivers to try out in that position (long time in car audio) - with only a few with a low Qts - I'd like to have a plan of attack so I get the install done in one weekend. I would just run out and measure, but I haven't taken delivery of my car, a coupe, yet. Again, thanks for the info. |
06-27-2018, 01:09 PM | #5 | |
1753
Rep 2,942
I had Hertz Energy ECX 100.4 coaxials installed in my car, which have a top-mount depth of 44mm. The spacer/adapter I used was from eBay and was originally designed for the F30 but was plug-and-play for the F22; IIRC, the lift was about 10mm.
06-28-2018, 01:22 AM | #6 | |
Rep 8
01-22-2019, 11:40 AM | #7 |
135
Rep 242
I was looking through some options and just want to clarify:
there are two depth issues here (with the fronts in the doors not the rears which have none): the space from the door card / OEM grille to the face of the speaker, and the space from the back of the magnet to the window glass. What is the max for each (not in actual measured space, but in speaker lingo 'mounting depth') i.e. when looking at the specs of a speaker from the manufacturers supplied info, how deep is too deep? And what is the max thickness spacer. (this would be for a mid woofer only not coax which has different issues due to the tweet) thanks, Seth |
01-31-2019, 04:19 PM | #8 |
135
Rep 242
here's what I was able to find in the forums...
the focal ISC100 which is a common add on is 49mm or 1.9" deep. So with an 18mm spacer or .7" it fit. the issue here was it puts the face of the speaker too close to the door card because it has a tweeter built in which sticks out the front of the speaker. With no tweeter its no issue. That sort of answers my question. Can't get a speaker deeper than 2" and can't get a spacer taller than 3/4". Or ignoring a spacer, you can only work with 1.25" of depth. unless someone can correct me. Since most high end speakers have a depth of over 2" - can a 2.25" deep speaker fit? Will a 1" spacer work? Seth Last edited by sethwas; 01-31-2019 at 04:26 PM.. |
Tags |
depth, midrange |
