F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Best brake pads for MPerf BBK
ARMA SPEED
      06-20-2018, 02:45 PM   #1
js 84
js 84's Avatar
84
Drives: F30 2012 320d
Hi Guys,
Can you help me and suggest some brake pads that you have used on your car and can recommend. I have MPerf brake kit.
If you have part number that would help significantly.
      06-20-2018, 03:28 PM   #2
cfm56d7b
5886
Drives: 2017 440i Gran Coupe & 2015 X5
What are your goals: reduce brake dust? Less squeal?
      06-20-2018, 04:26 PM   #3
js 84
js 84's Avatar
84
To keep good performance and preferably reduce squealing.
      06-21-2018, 06:27 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
I use Porterfield R4S which are formulated for Hi Perf/HD Street (I don't track my car)
https://www.porterfield-brakes.com/
  • For high performance and heavy duty street conditions the Porterfield R4-S compound remains a top performer in the realm of street/performance brake pads.
  • With the R4-S compound giving a friction level up to .41. This is an amazingly fast stopping brake pad. Simply put, they will give you an impressive increase in stopping ability with very minimum amount of pedal effort.
  • Perfect for prolonged everyday street driving while also being capable of enduring the most severe use without fade. It is also rotor friendly of course.
  • We have gone to great measures to ensure that the R4-S compound has the absolute lowest noise and dust levels possible, far below O.E.M. equipment or any other high performance brake material.
  • The R4-S compound which has an overall win in the Baja 1000 is available for most models of cars, trucks, and SUV’s. Superb stopping power under heavy use. Great for occasional autocrossing, solo events, off road events and rallies. Perhaps one of the overall best performing, clean and quiet everyday high performance driving brake pad ever made.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      06-21-2018, 11:17 AM   #5
FaRKle!
4016
Drives: 328d Wagon, M2 Comp, i4 eD35
How's the dust with the R4S? I'm considering it for my next street pad.
      06-21-2018, 11:59 AM   #6
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Very little - not down to the level of ceramic pads (which is low & usually very light in color), but no where near OEM pads. My wheels are black so even at that the dust doesn't show up so well
I had the CoolCarbon ceramic pads with all new rotors prior to the R4S and for stopping power they sucked + after a couple thousand miles they started to make noise on light braking & groaning upon braking in reverse
On my previous BMW I used the Akebono Ceramic pads & never had a problem with these issues, but unfortunately, they don't make them for my app
You'll never get the stopping power with a set of ceramics that you get with the Porterfields
      06-22-2018, 09:42 PM   #7
cola.p
32
Drives: BMW 530e G30
Centric Posi Quiet Semi-metallic is good for me. Part no. Front 104.16090 rear 104.16560. From my experience performance is on par to oem but less dust and more quiet. It’s very cheap.
      06-27-2018, 03:37 PM   #8
Johnny250
1044
Drives: 328d Wagon
I got HAWK HPS 5.0 BRAKE PADS.
Good bite, and my dust problem is 1000% better than OEM pads.
      06-27-2018, 03:51 PM   #9
Polo08816
1610
Drives: 2014 335i M Sport
Originally Posted by js 84 View Post
Hi Guys,
I run the stock M3/M4 brake pads in my M Sport Brake Option. Does not squeal in the spring, summer, or fall, and is track worthy in B run groups. The only downside is that it dusts a lot.
f30post
