M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Clutch Grabbing Lower, Notchy Shifts
      06-18-2018, 12:47 PM   #1
jessetaylor1
171
Drives: 2018 AW LCI
Hey guys,
3k miles on my 2018 M2 6 speed. Wagner catless downpipe, Hex Stage 2 tune. No other mods.
Past few days the clutch seems to be softer and engaging lower to the floor. The shifts seem to a bit notchy. Nothing too crazy just something I've noticed change since I've owned the car.
Thoughts on what it could be, or if I should bring it in for service?
Thanks!
      06-19-2018, 08:27 PM   #2
jessetaylor1
171
Drives: 2018 AW LCI
All day today the clutch engagement went back to normal, higher up on the travel and shifting was smooth. That was until later tonight it went back down and notchy shifts and soft pedal feel with low engagement.
Anyone have any thoughts?
      06-19-2018, 10:32 PM   #3
stefan
stefan's Avatar
No_Country
2350
Drives: M2 Comp
Mine does this too.. I'm chalking it up to heat and perhaps just break in. I also figure I'm getting used to it. Curious if you bleed and swap out to a higher quality clutch fluid...
///M Power
      06-20-2018, 12:25 AM   #4
cookiesowns
cookiesowns's Avatar
587
Drives: X5 45e, 535i N54, X3 N55
Clutch Master is shared with the Brake master....
So it's tied to your brake fluid unfortunately. I would flush the two together.
Heat and break in. BMW has self adjusting clutches, just give it some break in time and it'll go back to normal. I noticed this on my car. Was kinda weird around 1500-3000 miles, then it slowly got better.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
      06-20-2018, 09:14 AM   #5
jessetaylor1
171
Drives: 2018 AW LCI
Thanks for the responses guys. Makes me feel better. I'll be watching it for next few weeks and will update.
      06-20-2018, 02:19 PM   #6
DETRoadster
Space Force - 4 Star General
DETRoadster's Avatar
11463
Drives: M2 MG 6MT / Moto Guzzi V7
Same here. Thought I had air in the system at first. Asked the dealer and they said to just give it a little time for everything to settle in and self-adjust.
Appreciate 2
      03-23-2019, 07:52 AM   #7
jessetaylor1
171
Drives: 2018 AW LCI
Issue is back. This time clutch is grabbing higher and softer, less abrupt. Car is at 11,200 mi. Been going on for the past two days.
m2
