BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    NEW RELEASE! KW Height Adjustable Spring Kit (H.A.S. Kit) F90 M5
      06-12-2018, 06:58 PM   #1
AutoTalent
AutoTalent's Avatar
2301
Drives: e92 M3 6mt | e60 M5 6mt
Golan@AutoTalent.com
AutoTalent | KW Suspension | BMW F90 M5
H.A.S.
We are the oldest KW Suspension dealer in the country! So we can get the best price guaranteed.
The HAS (Height Adjustable Spring) Kit is used for lowering the vehicle in combination with the original dampers, even when electronic damper control is installed. This lowering solution from KW optimizes the dynamic performance and the steering behavior without the electronic damper control deactivated.
Part # 253200CC
The KW Height Adjustable Spring Kit (or "HAS Kit", for short) allows you to achieve the look you’re after on your 2018+ F90 chassis BMW M5 without having to sacrifice your factory electronic suspension. This kit allows you to re-use your stock M shocks, retaining all functionality, while decreasing costs and need for added parts. You get the perfect F90 M5 lowered ride height and retained EDC - so you can keep your variable ride control (Comfort, Sport and Sport+).
You used to have a choice: Aftermarket springs with pre-set static ride height OR fully adjustable ride height with a full coilover system. What do you do when you already have the most sophisticated dampers on your F90 M5 and all you want is increased performance with the ability to set your ride height? The KW Height Adjustable Spring Kit (or HAS kit, for short) is the answer, and gives you the best of both worlds on your street driven F90 M5.
Spring rates are developed specifically for the F90 chassis. The lowered ride height will not only make your M5 car look better (meaner!), but it also adds increased handling responsiveness. KW uses the same high-quality chrome-silicone steel as they do in their top-rated coilover kits, so the springs and adjusters are the quality you’d expect for an F90 M5, delivering both longevity and ease-of-adjustment. HAS kits are wonderful enhancements of your stock suspension, and are a perfect solution for newer BMWs, whether they come with a standard or adaptive suspension system. The KW Height Adjustable Spring Kit is designed to be the best fit and flexibility of any spring kit available for the F90 M5.
Ride height adjustability (5mm-20mm front and rear, or 0.2 inches to 0.8 inches)
Adaptive suspension remains active when equipped
Specific spring rates matched to the F90 M5
Better handling and corner with reduced body roll
Improved look and stance
The F90 M5 HAS Kit comes with the M5-specific springs, height adjusters, and F90-specific bump stops with dust protection system.
      06-12-2018, 09:01 PM   #2
Carmelle
32
Drives: M5
is this lower across the board (Comfort, Sport and Sport+) or does it mean that the more aggressive modes can go lower than before while retaining the comfort mode's height?
      06-12-2018, 09:11 PM   #3
josec70
josec70's Avatar
4051
Drives: 22' Individual Chalk M5C
I have KW HAS on my current F10 M5 and they have been phenomenal w/ zero issues to date. More than likely headed down this path w/ F90 M5 on order.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      06-12-2018, 11:07 PM   #4
esquire
esquire's Avatar
478
Drives: 2011 Dakar Yellow M3, 2018 M5
PM sent
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip]
[Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE]
      06-13-2018, 12:07 AM   #5
stbm5
261
Drives: 2018 M5 DG
Are there any negative consequences to lowering with this set up regarding the wear/dynamics/range of the stock shocks?
      06-13-2018, 04:50 AM   #6
josec70
josec70's Avatar
4051
Going on 3 years w/ zero issues. Stock shocks fine.
      06-13-2018, 12:29 PM   #7
AutoTalent
AutoTalent's Avatar
2301
The drop is set and does not change between the different settings. The shocks are still factory so you can choose between the different dampening settings.
Originally Posted by esquire View Post
PM sent
PM Sent!
The stock shocks will eventually go out but not anytime soon. I would say scraping the bottom bumper is more of a negative consequence if you don't angle the driveways right
      06-13-2018, 06:24 PM   #8
M4LAKA
91
Drives: 2022 M5 Comp
I wonder how the spring rates compare to the stock competition springs
Currently:
2022 M4 Comp xDrive
2022 M5 Comp
Past:
2019 M5 Comp
2015 M4
      06-15-2018, 06:48 PM   #9
esquire
esquire's Avatar
478
Re-reading this I have some confusion. Is the TOTAL drop .2-.8 inches? Or is that how much adjustability it has ON TOP of the initial drop? The language of the post implies the latter: "Ride height adjustability (5mm-20mm front and rear, or 0.2 inches to 0.8 inches)"
      06-21-2018, 01:59 AM   #10
AutoTalent
AutoTalent's Avatar
2301
We will be sure to update the thread with more information as we receive it.
The total drop range is 0.2" - 0.8", for a more aggressive drop coil overs will be the solution.
      06-23-2018, 04:16 AM   #11
GAM5OVR
54
Drives: 18’ M5
Interested in these but want to know if it will harshen the ride comfort?
      06-26-2018, 03:39 PM   #12
AutoTalent
AutoTalent's Avatar
2301
You still have the ability to go between comfort, sport and sport + on the dampening but overall they will become more firm. I have not had any seat time personally to give my overall opinion.
      06-27-2018, 12:11 AM   #13
stbm5
261
Drives: 2018 M5 DG
Yes for sure.
      07-06-2018, 03:12 PM   #14
DallasLife345M
595
Drives: Uber
Would the same drop range of 0.2”-0.8” apply to the M5 Competition model?
      07-10-2018, 06:50 PM   #15
wieisme
110
Drives: Chalk White F90 M5
Add to cart, just ordered today!
2018 Chalk F90 M5
2012 GTR Alpha X
IG: @chalkf90m5
      07-10-2018, 07:17 PM   #16
AutoTalent
AutoTalent's Avatar
2301
Drop will be the exact same as the non ZCP car as the only difference is the spring.
      07-10-2018, 08:56 PM   #17
DallasLife345M
595
Drives: Uber
Okay, still confused. The Competition comes from the factory about .25” lower than the standard model. So...
1. Will the Competion be a total of 0.4-0.8” lower from Competition factory drop?
Or..
2. Will the Competition be a total of 0.4-0.8” lower than the standard model?
      07-10-2018, 08:57 PM   #18
AutoTalent
AutoTalent's Avatar
2301
Or..
Competition is lower than the standard F90 M5. Both will be the same drop height after installing the KW HAS.
      07-10-2018, 09:08 PM   #19
DallasLife345M
595
Drives: Uber
Got it. Thank you for clarifying
      07-11-2018, 12:35 AM   #20
stbm5
261
Drives: 2018 M5 DG
Has anyone actually installed these and have a review?
      07-11-2018, 10:51 AM   #21
DallasLife345M
595
Drives: Uber
Can you PM me the price?
      07-11-2018, 10:57 AM   #22
Pitts
27
Drives: 2022 G82
Ordered a set a couple of weeks ago. Once I get them in and installed I’ll post some pics.
Jamesmick131.00
Search this Thread:
Advanced Search
m5post
