Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CCC Navi issue.
      06-11-2018, 09:10 PM   #1
ntpcrew13
ntpcrew13's Avatar
Philippines
110
Drives: Arctic e90 330i
CCC Navi issue.
I’m posting this for a buddy that is having an issue with his Navi. Any help would be greatly appreciated.
Having an issue with my CCC unit. After starting my car, I see the BMW logo on my nav unit, then the screen goes black. The screen then flashes a white screen before returning to a black screen every so often.
These are the codes that have registered for me.
S 0375 No communication with: Headunit
S 0374 No communication with: Aerial Tuner
S 0067 No communication possible with: Audio system controller
00A6CA JBE: Switch-on relay for windscreen wipers
00E187 CD/ M-ASK / CCC / RAD2 / CHAMP -GW: K-CAN communication fault
00A46D CID: CID malfunction due to periphery
Checked fuses behind glove an seem to be OK, also tried resetting the NAV by pressing all three buttons- no luck. Any assistance on what to do or how to fix this?
......support your local vendors. view my garage for a list of mods.
      07-16-2018, 07:12 PM   #2
Ntp_23
Drives: E90 Fire Engine Red 330i
Bump
      07-17-2018, 05:42 AM   #3
ptpending
ptpending's Avatar
456
Drives: e91
every CCC unit will die, pre-2007/03 more often
you should look ebay for post 2007/03 unit (with multiple buttons), this will be cheaper then send to repair yours
or if have spare 500-1000 - make upgrade to CIC and add bluetooth streaming via combox
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      07-26-2018, 08:21 PM   #4
reckhard
Drives: 2006 330xi
I'm having the identical problem (although I don't know what codes I may have). Screen is black and flashes white briefly about every 30 seconds. No audio system. Bluetooth seems to be active as my phone still connects but again, no audio. just before the screen flashes a green light by the SOS switch flashes. I'm concerned about just replacing the CCC unit as occasionally I'll start the car and it comes back (although it's been a few days since that's even happened for me). If anyone has had this same problem and found a fix please post...
      05-11-2020, 08:33 AM   #5
hitful
Drives: 2006 BMW 330Xi
having the exact same problem with my 06 CCC
e90
