06-11-2018, 07:53 PM | #1 |
Rep 19
Cerium Trim Part #'s
Im looking to install the cerium front grills, front air damn bumper trim and side vent trim
I searched and cannot fine any part numbers, any help would be appreciated |
06-11-2018, 09:00 PM | #2 |
113
Rep 193
Drives: '18 M550i, '15 Jaguar F-Type R
Ask the "getbmwparts" guys, they will know. Remember they are M550i parts when you search. Or you can always try to find someone in your area that swapped them out. If someone in western canada wants some, my set is sitting in the garage...
06-13-2018, 06:21 AM | #3 |
185
Rep 402
06-30-2018, 02:52 PM | #4 |
Rep 9
Im avtually trying to find black replacement parts for these parts on my M550. I found the side vents as im pretty sure theyre they same as any G30. The front cerium grill vents are what Im having trouble finding.
07-06-2018, 08:11 AM | #5 |
1140
Rep 1,136
Here are the Cerium part #'s:
Center Grille Left - 51138070471 Center Grille Right - 51138070470 Side Air Duct Trim Left - 51748063261 Side Air Duct Trim Right - 51748063262 Front Air Dam Trim Left - 51118063267 Front Air Dam Trim Right - 51118063268 Be aware though, based on what I researched, it seems that the Front Air Dam trim pieces for the M550 sit on a different grille part # than other models, as the M550 doesn't have fog lights. So if you are trying to install this on a model with fog lights, you may have to remove the fog lights in order to get this to work, as well as replace some other parts of the air dam. Last edited by roxxor; 07-06-2018 at 09:04 AM.. |
07-06-2018, 08:22 AM | #6 | |
Delrosa81
59
Rep 251
I'm having the G30 540i M Sport. I did not change the grille parts nor removed the foglights. Instead, I got the local dealership to fit it in and I do not find that it poses any issues. Below are some photos.
F20 LCi
JustChris17483.00 PunkMan21520.00 |
07-06-2018, 09:05 AM | #7 |
1140
Rep 1,136
That's good to see that it can be done, as that is ideally what I would want to get done on mine if I end up getting the Mediterranean Blue. Looks good!
07-06-2018, 02:59 PM | #8 |
113
Rep 193
Just a heads up, I have the Cerium Grey trim from my M550i available for sale. Parts include both grills, side vents, mirror caps and front bumper/air duct trim. There were removed before I took possession so they are new. Retail pricing is over $700 USD.
08-09-2018, 08:51 PM | #10 |
Rep 9
01-02-2019, 05:24 AM | #12 | |
Rep 21
Do you happen to know how they managed to fit them in? My understanding is that the "M Performance" bumper finishers are different from those of the M Pack, the air vent to the side being fully contoured on it (see image below). I guess that why they say you need to lose the fog light to have it, because the part number 51118063267 comes with the grille. If I understood correctly, for the "M Performance" finishers to fit in with the fog lights and the original M Pack grille, the additional guide need to be shaved? isn't it? |
01-16-2019, 04:24 AM | #13 |
11
Rep 99
Drives: 2021 M5 comp
Canuck99. Where did you find all the replacement parts for the grey pieces? I want to change mine out for all black or carbon fiber. Thanks.
01-16-2019, 04:36 AM | #14 |
11
Rep 99
Ok. Found the grills and air dam moldings. Now i only need the black mirror caps and fender pieces in black. Where do i go next? Thanks. 2018 m550 dark graphite
01-19-2019, 05:32 AM | #15 | ||||
Delrosa81
59
Rep 251
F20 LCi
06-28-2023, 08:18 PM | #16 |
Rep 23
Drives: 2018 BMW G30 M550xi
Do you know how they removed it from the bumper? Does it require unmounting the whole bumper or is there a trick to pull it with the bumper on? Mine's all scratched from a dodgy parking job one night. Wanted to replace it myself.
2018 BMW G30 M550xi
Past - 2016 BMW F06 650i GRAN COUPE / 2014 BMW F30 335xi / 2009 AUDI B8 A4 3.0L TFSI QUATTRO |
