Moly diffrence oils?
06-11-2018, 06:59 PM | #1 |
Rep 50
Hello what is the difference between 5w-30 Liqui Moly Longtime High Tech vs 5W30 Special Tec LL Engine Oil
06-12-2018, 08:29 AM | #2 |
Rep 50
per Liqui Moly
Dear James, thank you very much for contacting us and your interest in our LIQUI MOLY products. The LIQUI MOLY Longtime High Tech SAE 5W-30 and the LIQUI MOLY Special Tec LL SAE 5W-30 are both fully synthetic based but with completely different ingredients and so as a result different specifications. Our Longtime High Tech is a so called "low-SAPS" formulation and mainly used in diesel vehicles equipped with a diesel particulate filter (dpf) system. It has the BMW approval LL-04 which is not allowed to use in BMW / Mini gasoline fired engines outside central Europe - so no choice for your E92. The Special Tec LL is a "full-SAPS" formulation, mainly suitable for the use in gasoline fired engines and not suitable for diesel vehiclkes with a dpf system. It is BMW LL-01 factory approved which is the valid approval for your car. Thatīs the oil we recommend you to use in your BMW ! |
06-13-2018, 12:20 PM | #3 |
Rep 50
I asked the same question via facebook
Use the Longtime High Tech 5W-30. This one has the official manufacturer approval Longlife 04 ,which is required for your car. Which is it? I know ll04 is the new standard. I have e92 2011 328i. Going with either or i should have no issues? |
06-13-2018, 01:12 PM | #4 |
2341
Rep 3,542
On their site you got a pretty nice guide
https://products.liqui-moly.com/olys...a8184b2522d188 If you click on Special Tech LL 5W30, on the right side it says it is good for gasoline and diesel engines and it LL-01 approved. |
06-18-2018, 02:13 PM | #5 |
Resident Pedant
503
Rep 792
You need to use LL01 Oil if you're using North American gasoline.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
