Power jolts under vacuum in highway cruise? Any idea?
06-11-2018, 03:51 PM | #1 |
58
Rep 143
So all the sudden today on my way to work and back from work my N54 E90 started experiencing these power jolts/surge spikes.
At first I though it's a misfire, but its actually random power surge. It's only happening while cruising in vaccum just maintaining speed. My boost gauge actually registers quick spike in boost and my timing shoot up into advancing more. But it's only a random spike/jolt and happens maybe 2-4 times in 12 miles covered. No issues performance issues otherwise in WOT. No engine codes other that the usual no kitties and two shadown codes from running inline Walbro. Any ideas what it might be? 07 335i M/T JB4 G5 ISO no kitties Rennart CBE ARM Motorsports Stepped FMIC AL charge pipe Tial Q BOV NGK 5992 Plugs @ 0.022 CTS DCI Fuel it STG1 inline Walbro Running E57 |
06-11-2018, 04:00 PM | #2 |
39
Rep 108
Valve cover or Vcg most likely. Same exact symptoms I had at first before it got worse and I wasted time fixing other things lol. If you take your cowl and engine cover off and see oil anywhere then it's a guarantee.
My cars also an 07 and my gasket just went bad this past year too, same thing where I only had issues while under vacuum and everything. While you're in there light as well spend the extra $100 for new PCV parts or if you were considering an external pcv system you could do the whole thing right now. |
06-11-2018, 04:03 PM | #3 | |
58
Rep 143
06-11-2018, 04:08 PM | #4 |
39
Rep 108
Hmm, because of the symptoms I'm still thinking it has to be PCV or vacuum related but I guess it could potentially be your injectors leaking if your logs show any symptoms. Depending on how long ADE is gonna take you might want to just spend the $30-40 for a pic valve
