Idrive problem - youtube video
06-08-2018, 06:27 AM | #1 |
33
Rep 135
Drives: 2008 318i 6MT
Hello everyone,
Can you please watch my video, you will see what problem i have with my idrive. http://www.youtube.com/watch?v=6L3aMJVIHq4 Some of you have simillar problem? How did you fix it? Thanks in advance for help |
06-08-2018, 08:47 PM | #2 |
21
Rep 105
most likely your ccc contoller is faulty. the way that controller work is bt\y sending a can bus message to ccc @ 100kbs. so if your controller is acting like in your video, i would assume its got a bad contact/ cold solder and is randomly sending a can messages to you cccc
hope this helps Pozdrav. |
06-09-2018, 05:55 AM | #3 | |
33
Rep 135
Well i found something on YT , video shows how to repair contacts on knob Its just iam not sure is it for my problem P.S jel ti to mene razumiješ? ( just in case you understand my language ) |
06-09-2018, 12:25 PM | #5 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
Remove the idrive controller from center counsel. Go to Home Depot and by "contact cleaner" in the electrical isle and try and clean out the knobs switch contact. I would bet either the idrive controller is bad or you spilled a drink in it which is giving false contact closures. Contact cleaner is plastic safe, non conductive and evaporates fast. After spraying underneath the knob let it dry in the sun for an hour and reinstall.
06-13-2018, 12:34 PM | #6 |
33
Rep 135
Thanks guys for replay...i will try first clean contacts than if its not working ill do exactly what tutorial shows.
Hope i fix it that way.. Hvala Gray |
