06-06-2018, 03:07 PM | #1 |
24
Rep 30
Drives: 2018 X1 M-Sport
Aftermarket Blind Spot Detection???
I always wondered if there were any aftermarket blind spot detection systems that we can install. I was able to find this:
http://www.goshers.com/radar-blind-s...m-bsds-rd1630/ Has anyone ever used/installed this on their X1 or even a different car? |
06-08-2018, 10:37 AM | #2 | |
64
Rep 261
#1 Buy and install a round convex stick on mirror at the bottom left corner of your driver's side mirror...$5 # 2 Put down your cell when you start your car...$0 #3 Look in the wide angle mirror B4 changing lanes! $0 Only $5 and 30 seconds install...bonus..#2 will also cure "blind spots" through the windshield, rear view mirror and the right side convex mirror as well...a win, win, win! |
06-08-2018, 08:10 PM | #3 | |
Comfortably Numb
594
Rep 654
Drives: '18 x1/'13 X3/'06 330i
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
06-12-2018, 03:07 PM | #4 |
Rep 5
Would be curious to get a real answer to this question.
daneainsley23.50 A_fun_g0.00 |
03-02-2021, 02:02 PM | #5 |
22
Rep 81
Old post, but since the X1 is the wife's and she misses the blind spot/lane departure that her Benz had, has anyone added an aftermarket system? I have been reading reviews on several and the one that comes back as the "best" is Brandmotion RDBS-1500.
https://brandmotion.com/product/rada...ion-rdbs-1500/ Amazon better price: https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza It states on their site: "Known Issue Vehicles: BMW Vehicles Equipped With Auto Start-Stop" I wrote to Brandmotion stating that I have the auto start-stop disabled via the OBDII port/Bimmercode coding and can only activate it manually and this was their response: Thank you for contacting Brandmotion. In regards to your inquiry, we have not tested this functionality. In previous testing, when the auto start/stop is enabled, it will cut off the speed signal to the OBD2 connector. If yours continues to do this, our system will not work. You can test this by hooking a reader into your OBD2, and seeing if the reader can detect speed. My question: Will this work? |
03-02-2021, 02:26 PM | #6 | |
678
Rep 910
03-05-2021, 06:24 PM | #7 | |
22
Rep 81
Thanks |
03-05-2021, 09:12 PM | #9 |
22
Rep 81
03-06-2021, 05:09 AM | #11 |
678
Rep 910
If you want free app you can use ‘Car Scanner ELM 0BD2” it is available on Apple App Store. You will need to connect with 4.0 Bluetooth obd adapter (same as used for Bimmercode). To connect you will need to go into app settings under connection and select 4.0 Bluetooth (it will not always show up in iPhone Bluetooth setting) . This app when reading sensors gives loads of info including speed readings. I have tested in my X3 which actually has MHT 48v systems so stop/start cannot be turned off and it works fine sending speed data.
03-06-2021, 03:36 PM | #12 |
171
Rep 313
I have previously used both Torque Pro and Car Scanner. Both can connect to the ELM327 adapter in the OBD2 port and display real-time vehicle speed.
I tested in my 2018 X1 F48 with Auto Start/Stop disabled (using button next to the ignition button) and both Torque Pro and Car Scanner displayed the car speed while I was driving. |
MJE60678.00 |
03-10-2021, 02:13 PM | #13 |
47
Rep 231
I have the auto park feature with the extra sensors. Why didn't BMW use these for a blind spot detection system? And the next questions...can they be?
