05-29-2018, 07:30 PM | #1 |
Rep 26
Need help asap in coding
Need help on coding. I have the cable connected to my car but the top part never loads for me to select my model of car. Any help ??
05-30-2018, 03:28 AM | #4 |
588
Rep 2,302
This problem often occurs when you install E-Sys. But the solution is simple.
You have to manually add the empty folder "dist" under ...: \ Data \ psdzdata \ mainseries \ F020 \ F020_18_03_511_V_004_001_000 \ odx Do this for all mainseries folders and you can also see the other model selection. |
05-30-2018, 08:19 AM | #5 | |
Rep 26
05-30-2018, 08:32 AM | #6 | |
Rep 26
05-30-2018, 09:27 AM | #8 |
588
Rep 2,302
Yes, that looks good.
Now doubleclick psdzdata -> mainseries -> F020 -> F020_18_03_511_V_004_001_000 (maybe a different folder name to yours) -> odx And if you are in the odx-folder create a new folder named "dist". So rightclick -> New -> Folder Name this folder "dist". It than has to look like in my picture. If you have done this you can try to connect your car. |
