E90 LCI front spacers
05-29-2018, 07:21 AM | #1 |
13
Rep 206
Just need some advice please.
I'm running 18" staggered MV3 setup on my E90 LCI with eibach pro springs. I'm wondering what size front spacers can I get away with? TIA, Ad. |
05-29-2018, 07:39 AM | #2 |
92
Rep 660
Drives: E90 330D M-Sport LCI
Have you got spacers on the rear? If not I'd probably do that first as the rears sit inside the arches a good bit more than the fronts.
If you have then I probably wouldn't go any more than 5mm on the front though I've not done mine as I like the front how it is, plus I'm quite low up front. 10mm on the rear seems to be the going rate... |
05-29-2018, 07:47 PM | #4 |
Rep 14
I have 12mm spacers on my front, 18" setup E90 LCI. No rubbing. Looks fine. If they do rub you can likely return for shorter ones depending on where you get.
05-30-2018, 03:04 AM | #5 | |
92
Rep 660
