05-25-2018, 03:15 PM | #1 |
478
Rep 1,467
Grease for Suspension
What grease can I use on my KW coilovers to quite down the bump stops and the discs? I have seen this done before where it stops them from clanking over certain roads.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
05-26-2018, 02:06 PM | #2 |
993
Rep 1,934
Bump stops don't clank? That's something metal to metal. Bumpstops are usually a far more vibration absorbant material like polyurethane or plain heavy duty rubber.
If your coilovers are clanking over road imperfections look into the top mounts. Most coilovers will use a metal insert while stock uses rubber to absorb that nvh. I've seen someone on here swap out their coilover camber plate for Ksport plates, as those use a top mount like stock with a rubber insert. But for other coilover maintenence white lithium grease is good to use. I've used it on my old project BC coilover threads as winter salt prevention. Helps keep the threads clear for easy adjustment. I believe I used Boeshield T9. Cheap online anywhere.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
05-26-2018, 02:40 PM | #3 | |
478
Rep 1,467
05-30-2018, 07:56 AM | #4 | |
478
Rep 1,467
05-30-2018, 09:40 AM | #5 |
993
Rep 1,934
Shim it to keep them in place
