Trans cooler setup, catch can, dpf!x, walnut vacuum adapter, blt
05-24-2018, 08:33 AM | #1 |
80
Rep 273
Have a custom catch can, internally baffled, much better than most setup's out there. Has a drain, two inlets and one outlet. Will need ADE fittings, or can tap the valve cover. No lines included, but will include a fitting for the intake (relocated alum needs fitting welded on, if using stock location, will include a fitting that fits in one of the dv recirc ports). $180 3" boost leak tester, 3 ply coupler, gauge, valve stem. Brand new $35 walnut blasting vacuum attachment, $30. new trans cooler setup. B&m core, 160* thermostat, transmission line adapters and all an lines/fittings. $485 plus shipping. Oil cooler setup, b&m trucool core, 160* thermostat, an fittings/lines, and oil cooler adapter plate. $400 Prices dont include shipping.
2008 BMW 135i - VRSF Race FMIC - VRSF Charge Pipe w/ Tial BOV - 3.5" Downpipe - SM Exhaust - SM Top Mount w/ BW S366 - 450 & 525 bucketless - SMS Catch Can - SMS Oil/Trans Cooler
Facebook.com/SpoolnMotorsports Last edited by 335igasm; 06-20-2018 at 11:27 PM.. |
05-29-2018, 11:56 AM | #3 |
80
Rep 273
Devils own pump, Burger Tuning reservior, fsb and solenoid, cooling mist nozzels
Facebook.com/SpoolnMotorsports |
05-31-2018, 07:21 PM | #5 |
80
Rep 273
ok
06-02-2018, 04:06 PM | #6 |
80
Rep 273
Up top
06-05-2018, 11:19 PM | #7 |
80
Rep 273
Added dpf!x, blt and walnut blasting vacuum adapter.
06-06-2018, 03:35 PM | #8 |
41
Rep 220
Is the DP Fix for N55? I might be interested in the oil catch can too if we can strike a deal on both.
And when I die, make sure you spread my blood on a BMW 2012 E92 335i xdrive | KW V1 Coilovers | ER Chargepipe | VRSF 7" HD | VRSF Catless DP | MHD Stage 2+ | xHP Stage 3 |
06-06-2018, 09:15 PM | #9 |
80
Rep 273
N54 :/
06-09-2018, 04:45 PM | #10 |
80
Rep 273
Edited first post. Also have a new trans cooler setup. B&m core, 160* thermostat, transmission line adapters and all an lines/fittings. $485 plus shipping.
06-14-2018, 08:05 AM | #12 |
Master of Montego Blue
28
Rep 500
06-20-2018, 11:27 PM | #15 |
80
Rep 273
Removed sold items
