Can someone look at my Alignment Sheet
05-16-2018, 04:50 PM | #1 |
63
Rep 307
Still Trying to find a good alignment shop and today I finished the Front Suspension Upgrade of BMWPS and B8, also installed M3 Control and Thrust Arms along with new mounts and pads.
This alignment sheet has no key and I was so pissed at the shop when I left I just left...Long story there but just wanting help deciphering this sheet. No Key for their Symbols on the page anywhere so I am just guessing but I think it's my Caster that is 7.66/7.58?? Not sure what the Second Symbol is but it is out too with -1.24/-.96 is this Toe? Third symbol???? I want words not symbols, this is an alignment not a text TIA for the help |
05-16-2018, 05:13 PM | #2 |
2124
Rep 2,758
Caster is first symbol, camber is second, toe is third
Was going off symbols, looked at specs and I was wrong. Last edited by IllSic_Design; 05-16-2018 at 05:25 PM.. |
05-16-2018, 05:17 PM | #3 |
63
Rep 307
05-16-2018, 05:22 PM | #4 |
63
Rep 307
So what is the opinion on this alignment.
That caster seems a little much, I think I read somewhere E9s are around 6 normally but I am not sure. Thanks |
05-16-2018, 05:26 PM | #5 |
2124
Rep 2,758
05-16-2018, 05:29 PM | #6 |
2124
Rep 2,758
Caster is non adjustable unless you have caster/camber plates. Either worn parts/bushings or bent parts can cause caster to be off.
05-16-2018, 05:33 PM | #8 |
2124
Rep 2,758
Barefoot-335is62.50 |
05-16-2018, 05:34 PM | #9 | |
63
Rep 307
Only thing I haven't replace yet is Tie-Rods |
05-16-2018, 05:45 PM | #10 |
2124
Rep 2,758
Like I said caster is not adjustable unless you have special parts installed. It is not anything to worry about unless one is way off from the other, then something is bent/not right. Stock is around 7*, you're fine.
05-16-2018, 10:49 PM | #12 |
4276
Rep 9,206
Caster is Ok. Front camber is uneven and will pull slightly to the right. Rear toe might cause inside tire wear.
IllSic_Design2124.00 Barefoot-335is62.50 |
05-17-2018, 06:01 AM | #13 |
63
Rep 307
05-17-2018, 06:53 PM | #14 |
63
Rep 307
So, while I had it in for alignment after the suspension install I also had them install 2 new tires on the front. My 225-40/18 were shot so I grabbed some 235-40/18's.
Well, now when I back out and turn they are rubbing on the cooling vents in the front tire well, the ones for the oil cooler and additional remote radiator (335is). Why does it only rub when in reverse and not when going forward? I didn't think 235's would rub, still on stock 313's 8x18. Tires are BFG Sport Comp 2 A/S |
05-29-2018, 03:42 PM | #15 |
63
Rep 307
So, I had the car re-aligned today at a much better shop.
The guy doing the alignment seemed to really understand BMW's. The alignment is much better and the results are good. The car has been to 3 different shops for alignment in 2 mos and funny thing is is that this last guy was the best and the cheapest, price wise. Go Figure. |
