330i Issues
05-15-2018, 08:00 AM | #1 |
Rep 26
330i Issues
I have owned my 330i for nearly two years now, its currently sitting at 82k miles and I have started to receive some issues. The car is a 58 plate, and has recently had all plugs and injectors replaced, however, I only had the injectors replaced about 2 weeks ago, and now, sometimes when the car is stopped it sits on really low idle and has occasionally stalled. The car is an auto. It only seems to happen when the engine temp is hotter, as it runs like a dream on cold start, but then as it gets hotter it starts to run a bit lumpy when your not moving, and occasionally stalls.
Also, when the car is in park it can sometimes run lumpy after a run. Any ideas or help on this would be great, just want to see if anyone would know what the issue would be. |
05-15-2018, 02:48 PM | #2 |
Rep 40
I wonder were the new injectors coded correctly. Also it probably would be a good idea to check what fault codes if any and then maybe a reset of adaptations. Consult bimmerprofs for loads of info on this engine.
Tags |
330i bmw e92 |
