F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Rear toe, alignment settings?
ARMA SPEED
      05-14-2018, 03:09 PM   #1
PLuKE
Drives: n/a
Hi, I am after alittle advice.
Currently have a F31 M Sport with 19” 403m wheels. I have noticed the inner rears are wearing quicker than the rest of the tyre.
Camber didn’t look excessive, I am assuming rear toe is causing this wear, does anybody have a setup I can use to stop the rear wear?
Everything is stock, and using Conti RFT.
Many thanks
      05-15-2018, 07:41 AM   #2
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
On my F30 msport the stock rear camber was ~ -1.3degrees so there is some from the factory.
      05-15-2018, 01:54 PM   #3
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
You'll need to bring it to an alignment shop to make sure toe is in the green range. If it's not, then get it fixed. If it is, then something else is causing the wear. i.e. too much camber for how you drive, too much tire pressure, wheel bearing, etc.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
f30post
