Sport Strut Coil Spring not Straight
05-13-2018, 10:29 AM | #1 |
Rep 13
I'm replacing my leaking front strut and was planning to just swap the coil spring over to the new strut. But the coil looks like it has been warped and isn't straight anymore. Is this normal? I'm sure it would straighten out after compressing and placing the top hat on, but feel like the coil would be fighting against it's natural compression motion now and fail prematurely.
This on for M-Sport strut and coil, if that makes it any different. |
05-13-2018, 06:10 PM | #3 |
Rep 13
Yea I got new upper and lower pads and new strut mounts. The problem I'm having is getting the spring to compress enough to get the top hat back on. The spring is bowed too much I think.
I've tried using the standard two rod compressor and just bought a single action compressor from Harbor Freight, still can't get it compressed enough to remotely get the top hat on. |
05-13-2018, 07:04 PM | #4 |
Resident Pedant
503
Rep 792
I installed my BMW Performance Suspension springs with the tools in the background of your pictures, and they're shorter than your springs. Your springs look totally normal to me. The PS springs did not "sit straight" on the lower mount when they weren't under tension.
Have you pulled the strut arm all the way out? If it was pushed in you might have more trouble. |
05-13-2018, 07:41 PM | #5 | |
Rep 13
I was able to get the spring compressed finally by placing the compressor rods, had to use 3 of them, onto the top hat and spring. Got it compressed enough that I could get the nut started on the hat. Once I got that going I tightened the nut down fully without the strut mount. Now I need compress the rearrange the spring compressors to get it compressed enough to undo the nut and put the mount on. One thing I noticed is the spacing around the strut piston and spring is not even on all sides. Is that normal? In the picture the spring is closer to the piston on the left than the right. |
05-14-2018, 07:32 AM | #6 |
63
Rep 307
This is how I arranged my Spring Compressor....
I borrowed the pic from the 1series guys but I used his DYI to install mine. http://www.1addicts.com/forums/showthread.php?t=1447749 Hint: Just make sure that you stay away from the end of the springs when placing the compressor and place them in positions that won't be caught in the compression of the springs Sorry, can't get the pic to show up but just use the link and see how he has the spring compressor attached to the strut |
05-14-2018, 07:20 PM | #7 |
Rep 13
Hmm, you guys didn't show up in my searches when I was looking for parts. However, that is much more costly, for me in my situation, compared to the ~$355 I paid to refresh the front struts minus the springs. Plus lifetime warranty from FCP.
I would have liked to have upgraded to the Bilstein B8s but they're backordered everywhere and my left strut had completely failed, riding on just the spring. I'll keep you in mind for next time. |
05-15-2018, 12:03 AM | #8 | |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
feuer4275.50 |
05-15-2018, 09:59 PM | #9 |
Rep 13
I ended up going to Eastwood and buying this bad boy. Worked like a charm! I was able to get it compressed all the way. Much quicker and safer. Thanks for all the help guys!
06-04-2018, 10:26 PM | #10 |
1679
Rep 3,645
If the struts are already in the car I wouldn't worry about it but your bumpstops are in upside down. Glad you got the spring to compress and good choice on FCP.
Tags |
coil springs, strut |
