The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Eccentric Shaft Sensor Seal
      05-12-2018, 03:26 PM   #1
gsilk93
Drives: 2006 325xi
Hey guys,
I had some engine leaks and decided to take on the Valve cover gasket project myself, everything went will so far until I started having some problems with putting in the eccentric shaft sensor seal on my 2006 325xi with an aluminum valve cover. Are these seal the same for both the plastic and aluminum covers. For hell I cant get it in to fit. It seem bigger than the whole.
Any help will be greatly appreciated.
      05-15-2018, 06:48 PM   #2
madskillzE90
25
Drives: E90 AWD
This happens to the best of us, your original gasket is still installed or at least the top ring of it. Use a flat head screwdriver and get under the ring and pry upward. Once you remove it the new one will pop right in very easily.
