F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Performance Brakes Rear Rotors Does Not Fit
Studio RSR
      05-10-2018, 03:59 AM   #1
F30wasty
18
Drives: 2013 328i xdrive sport
I have a 2013 328i X DRIVE I installed M performance brakes but the rear rotors did not fit because I do not have E brakes the style number ends with 598 for the rear rotors apparently I have mechanical brakes does any one know what style number I'm suppose to get my stock rotors are bigger.
      05-10-2018, 05:59 AM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Your pics are of the front rotors not rears...
But as to the rear rotors, according to realoem.com for 3' F30 328iX using dimpled/slotted rotors:
For vehicles with
M Sport brakes
Alternate part: Original BMW Accessories
S2NHA=Yes
Brake rotor, ventilated, drilled, rear 345X24 2 34206797600
For Plain Rotors MPerf:
For vehicles with
M Sport brakes
S2NHA=Yes
Brake rotor, light blue, ventilated 345X24 2 34206797607
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      05-10-2018, 06:06 AM   #3
F30wasty
18
For vehicles with
M Sport brakes
S2NHA=Yes
For vehicles with
M Sport brakes
S2NHA=Yes
Yes I'm just showing those the rears have not been changed
      05-10-2018, 06:38 AM   #4
F30wasty
18
For vehicles with
M Sport brakes
S2NHA=Yes
For vehicles with
M Sport brakes
S2NHA=Yes
So will the part number ending 600 will fit for me ?
      05-10-2018, 02:00 PM   #5
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
For vehicles with
M Sport brakes
S2NHA=Yes
For vehicles with
M Sport brakes
S2NHA=Yes
Yes. 600 will fit on your car.
But that's not because 598 is for E-Brakes.
All F3x have mechanical emergency brakes, but they vary in two sizes on the inner disc diameter.
598 is for 335i/340i like cars 600 is for US 328i/330i and lower engines.
https://1drv.ms/x/s!AqdJMMUQxA-nhZs6p6H-qIavCJRWpQ
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      05-10-2018, 02:50 PM   #6
F30wasty
18
For vehicles with
M Sport brakes
S2NHA=Yes
For vehicles with
M Sport brakes
S2NHA=Yes
Thanks for your help guys
      05-10-2018, 03:59 PM   #7
7iM3less
7iM3less's Avatar
2595
Drives: F80 M3 ZCP
Amazing how every other person who does this mod manages to have the same problem.
Good luck op, it'll look fantastic when done!
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      05-10-2018, 08:22 PM   #8
Kailec
Kailec's Avatar
595
Drives: 2013 328i xDrive
Omg this is giving me flashbacks to 2 weeks ago when I had this exact problem. I literally had the car on the hoist and I went to get cash and a coffee while the shop was doing the swap. Then I get a call saying that the rotors don't fit. I eventually got the 34206797600 rotors that oceanview mentioned here. I know because I have the exact same car with the same sized rotors. To my understanding the 598 is for RWD 328/330 and lower cars and 607 is for xDrive plain rotors, 600 is for xDrive drilled and slotted rotors. The 598 rotors have a hat that's too small for the knuckle of the rear rotors. In any case 607 is what you need for your car.
      05-10-2018, 09:28 PM   #9
FaRKle!
4017
Drives: 328d Wagon, M2 Comp, i4 eD35
The 330 RWD uses the large hub rotor now (same as the xdrive one).
Only the 320/328i RWD cars used the small hub 598 rotor. All xDrive, 6cyl models, and 330i RWD use the 600 large hub rotor.
      05-11-2018, 12:17 AM   #10
oceanview
oceanview's Avatar
Switzerland
207
the best thing is to look up in www.realoem.com for your specific car entering your cars VIN code or at least your car detail AND production date.
There is also a difference between Europe and US models.
With entering the VIN Code you should be fine finding the part that fits.
http://www.realoem.com/bmw/enUS/part...00&series=F30N
f30post
