The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Single turbo wastegate pressure
      05-09-2018, 04:19 PM   #1
rominun
170
Drives: 2008 Bmw 135i
Just got a 335i with a single turbo that i fixed up. car runs great but doesnt hit more than 5 psi. the wastegate springs are at 13 psi. No codes come up, other than O2 sensor and oil level sensor. Can the O2 cause this? im pretty sure the car should run at 13 psi if the solenoid isnt connected
      05-09-2018, 04:28 PM   #2
rominun
170
heres a csv file.
https://drive.google.com/file/d/1rIH...w?usp=drivesdk
      05-10-2018, 12:20 AM   #3
nOshi
nOshi's Avatar
22
Drives: TiAg E90 335i
If everything is working as it should, I would look at the tune. If your flash only will need boostbox and if jb4 should have the correct firmware loaded. If not running either would explain not hitting target.
      05-10-2018, 12:28 AM   #4
rominun
170
im running jb4 single turbo firmware 135 and mhd backend flash with single turbo flash
      05-16-2018, 08:08 PM   #5
nOshi
nOshi's Avatar
22
Hopefully you got this sorted already. But upload a log so can see the full picture. Could be a boost leak or hardware.
      05-18-2018, 01:22 AM   #6
rominun
170
ended up being a boost leak. still doesnt hit target boost. hits 17 psi out of 23 right now. i ordered a boost leak tester and going to try to figure out the new issue
