Alignment recommendations? Using Dinan specs as a baseline?
05-08-2018, 03:33 PM | #1 |
BMW Portland
224
Rep 524
Hey guys, I plan on doing M3 control arms, front E93 sway bar, and ST coilovers next month. Currently I am trying to figure out what alignment specs I should set the car up with. I DD the car 15-20k miles a year, but most of those are country road miles with a lot of fun twisties. I plan on doing *some* track days and autoX this summer, but the car is primarily a street car.
I have had a few customers set up their cars with the Dinan spec alignments and I haven't heard anything but praise, so I figured I would start there. Here is the Dinan alignmnet spec sheet for a 335i with stock suspension: http://files.dinancars.com/webresour...1c0cc5a2c5.htm And here is the Dinan Alignment spec sheet for a M3: http://files.dinancars.com/webresour...d77cd7d233.htm Considering the I will be using M3 control arms, should I go with the M3 alignment specs? Also, how significant of a difference is there between Dinan's Stage 1,2,3? Is it worth it to go aggressive? Thanks!
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
05-08-2018, 10:13 PM | #3 |
BMW Portland
224
Rep 524
05-09-2018, 11:27 AM | #5 |
164
Rep 2,556
I'd shoot for -1d front camber, -1.8d d rear camber. Any more on a DD will result in excessive inner tire tread wear.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
05-09-2018, 02:25 PM | #6 |
4276
Rep 9,206
05-09-2018, 04:52 PM | #8 |
BMW Portland
224
Rep 524
This is why I was asking. I want to get the car as sharp as possible without going overkill on the daily-drivability aspect.
05-09-2018, 05:57 PM | #9 |
Guest
Rep n/a
Drives:
Well, every car/driver is different, but here are my specs and a good link to some camber/toe fundamentals that should help you out:
http://www.e90post.com/forums/showpo...21&postcount=2 My car is a daily driver (~10k miles a year) that never gets tracked. Most all miles are driven gingerly and spirited driving is sporadic. From a "daily-drivability aspect" my alignment setup has been working great so far and the car drives WAY better than it did with stock -0.4* front camber, -1* front camber, and even -1.5* front camber. Tires have ~55k miles on them and are continuing to wear completely even. CN: don't be afraid to add camber to a daily |
05-09-2018, 06:31 PM | #10 |
72
Rep 365
For a daily driver i'd go with as much equal negative camber as you can in front, should be -.8 to -1.5 with alignment pins pulled, equal negative camber in rear around -2, zero toe all around. You could do 1/16th toe in up front for more highway stability but most people won't notice the difference. This will be fun and not kill tires. Good luck
05-10-2018, 11:04 AM | #11 |
Basic Bimmer
518
Rep 935
Drives: E92 328i 6MT ///M
Why so much neg. camber in the rear, guys? I'm just starting to look into alignment specs for my 328i. Coming from Japanese RWD cars, I've always liked neg. 1.5 up to neg. 3 in the front, and always less (by about 33%) in the rear. I'd rather my car oversteer.. I know how to drive unlike the rando sheep that BMW sets the car up for at the factory.
05-10-2018, 01:35 PM | #12 |
Guest
Rep n/a
Drives:
05-11-2018, 10:21 AM | #13 |
BMW Portland
224
Rep 524
So I take it as max out the camber on the front (by removing the pins), and dial in around -1.6 to -1.8 camber in the rear? Then toe to taste?
05-11-2018, 12:57 PM | #14 |
72
Rep 365
05-11-2018, 02:22 PM | #15 |
BMW Portland
224
Rep 524
Sweet. Thanks everyone for the info. Looking forward to dialing the car in.
05-11-2018, 05:53 PM | #16 |
164
Rep 2,556
Huh? That was my experience when I ran more than -1d up front and ever so slightly toed in.
05-13-2018, 03:01 PM | #17 |
Guest
Rep n/a
Drives:
Blown95ImpalaSS71.50 |
