05-03-2018, 04:16 PM | #1 |
Rep 12
rear view camera retrofit
Hi All,
I really wish I had rear view camera on my car and spoke to the local dealer who advised that I need following parts:- 66557942742 - Rearview Camera 66212450878 - Retrofit Kit Both of these come to less than £300 The parts team then looked at the instructions and suggest it will take 4 hours but both the power and data connections are all in boot, has anyone got any experience of this as the labour cost is £530 and I am thinking of going elsewhere Or even a copy of the instructions? |
08-08-2018, 02:41 PM | #4 |
Rep 15
01-28-2019, 02:43 PM | #5 |
Rep 10
Hello,
I found this topic very useful. I still have a small situation that i would like to clarify with you here. Maybe we could find a solution. I bought the OEM retrofit kit from BMW AG and separately the camera from a friend with spare parts. I've started to look into the documentation and confronted with the reality on the car. When it comes to module Z2 rear right fuse box for the G30, I was not able to see available on the car, the slot Z2*3B where the open cable A3 should be plugged in. Is there any other connector that needs to be present (the actual Z2*3B) before trying to plug in the miniature connector G? Can I use other location from the rear right fuse box? I'm looking forward for your answers. Later edit: Please see the attached file with the fuse box. Best regards, Sebi. Last edited by sebica79; 01-28-2019 at 02:51 PM.. |
01-28-2019, 06:43 PM | #6 |
281
Rep 531
I have the rear view camera but would love to retrofit a front camera. Just asked dealer today and he said not possible because wiring isn't there and coding needed. How did you find part # for retro fit rear? Do you know of a kit for front camera? I'm not trying to get the 3D view but just front camera to work like rear.
US G30 540iX M sport Thanks
JS
01-29-2019, 01:59 AM | #7 | |
179
Rep 358
01-29-2019, 11:45 PM | #8 | ||
281
Rep 531
Oversight on my part. Someone is trying a 3D camera retrofit but a lot of effort. All I want is the front for pulling into parking spaces.
JS
07-04-2019, 02:17 PM | #9 | |
Rep 7
I have the same issue |
09-09-2019, 10:44 PM | #11 |
Rep 7
09-09-2019, 10:55 PM | #12 | |
Rep 7
09-16-2019, 06:38 PM | #13 |
1780
Rep 3,051
It could be eariler version of iLevel, try to upgrade it and it should be good.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
10-02-2019, 05:21 PM | #15 |
541
Rep 1,894
Hi all,
This is one retrofit that didn't come with my car. Should be easier compared to upgrading my F31 from non-Nav + Combox to ProNav. Anyway so it might help others the PDF cable codes refer to: GN - Green GE - Yellow WS - White |
11-20-2019, 11:09 AM | #16 |
606
Rep 1,454
Does anyone know how you would code in the retrofit kit (genuine) using eSys ??
Is it just a case of activating parameters (which I'm comfortable with) in existing modules or is it more involved ? The instructions refer to using ISTA/P I think but would have thought esys should be able to do the same thing. Any advice welcome |
11-30-2019, 08:04 AM | #17 |
Rep 4
Hopefully taking delivery of a new G30 m sport in a few weeks time, at the price I couldn't spec any extras. What I would've liked was power fold mirrors and reverse camera, personally think they should be standard features on a premium car.
I can live without the power fold mirrors, but would like to retrofit the reverse camera, came across a kit on eBay https://rover.ebay.com/rover/0/0/0?m...2F254202780386 Does say in description that it's OEM anyone had any experience, I know I have to code it, had an E60 years ago and had ISTA but that laptops knackered now, hoping someone in the Midlands has the kit to code for me and if possible give me a hand in install. All help appreciated |
11-30-2019, 09:29 AM | #18 | |
1780
Rep 3,051
Coding is also easy. PM me for more. |
11-30-2019, 09:35 AM | #19 | ||
Rep 37
12-01-2019, 04:31 AM | #20 | ||
Rep 4
12-18-2019, 06:05 AM | #22 | |
Rep 7
It was remote coded a while ago, by Bimmertech USA, and didn’t work following that. It was at the dealership on Monday for a recall job and I asked them to look in to it and check the connections at the BDC plugs as they are tricky to make. They said they “programmed” it but was still not working and suggested I remove and reinstall, my instinct was still to check the BDC plugs which they hadn’t done. When I drove the car home.......the camera is now working. I can only assume this is because a software update was performed also. It maybe never worked with them as it maybe has to go to sleep for a while, I’m not sure. I seem to remember the coder telling me to wait half an hour before trying it. |
