05-03-2018, 07:21 AM | #1 |
Two turbos are better than one!
119
Rep 404
Rattle with brakes - Need help
Hi all,
I have recently had a brake job done on my 2013 F30 with M-Sport brakes (Blue Brembos). I went from stock m-sport rotors to OEM M-performance rotors, and have replaced the stock pads with Hawk HPS 5.0 pads. However since the brake job I have a wheel speed dependent (not engine speed dependent) pulsing squeak/rattle which does not go away when applying the brakes. Upon checking each wheel, I believe it is coming from the front left brake area. Everything about the brake job appears fine and the same with one exception. On each pads there are 2 silver tabs (Not sure what else to call them) that sit at the back of the caliper and just outside the spring. On 3 corners, all of these tabs are tight and don't move, but on the front left the bottom two tabs are loose and I can wiggle them. I am wondering if this is causing the problem and if others have experienced such a situation. As a reference, here is the picture of the pads with the tabs I am speaking of, and I will try to link to the sound clip I tried recording of the issue. https://drive.google.com/open?id=1Z7...22VKXgGJwjciLD Thanks
Sapphire Black M4 Competition |
05-03-2018, 06:47 PM | #2 |
356
Rep 688
Drives: 22 TR X3MC
Either the pad was installed wrong or your caliper is seized
2022 X3M Comp
2013 335i xDrive (Sold) |
05-04-2018, 06:34 AM | #3 |
119
Rep 404
In talking to Hawk Performance, the tabas are counterweights and are not supposed to move. Might have to replace the pads.....
