04-29-2018, 09:40 AM | #1 |
478
Rep 1,467
Can’t Reset Rear Brake Pad Service Light
My idrive says resetnpossible but when I go to do it, it says reset unsuccessful. My rear pads have plenty of thickness left. I may have forgot to reset the light when i installed the m performance brakes about 10k miles ago.
Anyways why would this happen? Did the sensor break? Are those one time use? I did track the car last weekend and maybe that played into this happening.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 Last edited by Insane435; 04-29-2018 at 04:09 PM.. |
04-29-2018, 10:55 AM | #3 |
8245
Rep 16,088
If the sensor has been tripped then it must be replaced or you'll get the reset failed message. I found this out when I replaced my pads after it tripped and tried using the old sensor, with the same result. You can use the old sensor after a pad change only if it was never tripped.
04-29-2018, 04:10 PM | #5 | |
478
Rep 1,467
04-29-2018, 05:44 PM | #6 | |
8245
Rep 16,088
http://f30.bimmerpost.com/forums/sho....php?t=1471617 |
04-29-2018, 09:03 PM | #7 | |
478
Rep 1,467
Regardless, do I need new pad sensors still?
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
04-29-2018, 09:06 PM | #8 |
1781
Rep 4,456
04-29-2018, 09:08 PM | #9 |
478
Rep 1,467
Its says like 300 miles until pads need to be changed.
04-29-2018, 09:34 PM | #10 |
8245
Rep 16,088
I can absolutely guarantee that if you don't order it with the pads you will, and then you'll have to pull the wheel again to change it. I changed my pads, left the old sensor in, and it would not reset. I was smart enough to check it before putting the wheel back on, and I had the new sensor that I'd ordered just in case. I changed the sensor and the reset took. My front sensor had not tripped, so I was able to re-use it.
04-29-2018, 09:35 PM | #11 | |
478
Rep 1,467
04-30-2018, 07:58 AM | #12 |
27
Rep 36
04-30-2018, 01:04 PM | #13 | |
93
Rep 397
04-30-2018, 04:54 PM | #14 |
518
Rep 891
Same findings here. Replaced my pads with a few MM of material left before tripping sensor. Popped it right back in and got away without spending another 12 bucks.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-05-2018, 06:42 PM | #15 |
559
Rep 1,127
I ran into a similar issue and it was caused because the clock on the computer was unset (because I had pulled the battery negative lead). Make sure the time is set.
05-07-2018, 08:18 AM | #16 |
478
Rep 1,467
fixed! Somehow the sensor wire broke... i figured something went wrong.
