2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Changing brake pads
      04-28-2018, 12:25 PM   #1
MarcoZandrini
444
Drives: 2018 M240i
Changing brake pads
I tracked my car at Virginia international Raceway (VIR) over the first weekend of April. I've bought PFC-08 pads for both the front and the rear brakes. I checked on realoem, but it's unclear if the caliper has to be removed to change pads. However, the new pads have holes at the top of the backing plate so am I safe to assume that I can change them without removing the caliper?
Thanks!
      04-28-2018, 01:35 PM   #2
123Britt
287
Drives: 15 M235i AT
Brembo - NO
Not required to remove caliper. 2 pins and spring clip.
      04-28-2018, 01:38 PM   #3
overcoil
3074
Drives: M235i 6spd
SEARCH on this forum for a thread about brake piston retraction tool
And https://www.racingbrake.com/product-p/ccp01.htm
      04-28-2018, 08:47 PM   #4
MarcoZandrini
444
Drives: 2018 M240i
Fantastic! I thought I would have to pull the caliper. That’s a bit of work!
Many thanks!
      04-28-2018, 09:00 PM   #5
overcoil
3074
Drives: M235i 6spd
Many thanks!
I actually like brake calipers where you slide off the caliper slide pin bolts to remove the pads. But I guess at the track the Brembo style system is easier.
I suggest not using a pry bar against the disc to press the piston back in.
      05-01-2018, 11:08 PM   #6
ggggbmw
433
Drives: 2017 M2 Manual
OMG! That is about the worst video on how to change the pads in our car that I have ever seen. What a bunch of clowns. But then again, if these dopes can do it, you can see that anybody can do it. You certainly can't do worse.
Biggest tip I can offer over this video is to push the pads back against the piston while the pads are still in place. If you open a bleeder screw (with a catch bottle attached), you can push the pistons back with your bare hands. Maybe stick a screwdriver in between the pads and disc to push back if the pads are really worn. This also solves the 'how do I push both pistons at the same time' issue if you do it while the pads are still in there.
      05-02-2018, 08:16 AM   #7
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
for the pfc08's, just zip tie your sensors into the wheel well and re connect them when you put your street pads back in.
They are amazing pads, loud as fck tho. Remember to change your brake fluid to a higher boiling point.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      05-02-2018, 10:10 AM   #8
MarcoZandrini
444
Drives: 2018 M240i
Yeah, that's how I've changed pads in my bimmers for years. Works great.
      05-02-2018, 10:11 AM   #9
MarcoZandrini
444
Drives: 2018 M240i
I'm flushing the brake fluid with Motul R600. Thanks for the tip about the pad wear sensors. I'll bring some zip ties.
      05-07-2018, 05:48 PM   #10
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
My tip that I don't see mentioned often. Crack open the reservoir cap on the fluid before pushing the calipers back. Make sure the area is completely clean before cracking open the cap.
Don't forget to tighten the cape when done!
      05-11-2018, 12:12 PM   #11
MarcoZandrini
444
Drives: 2018 M240i
Actually, I usually remove some the fluid in the reservoir before I push the pads back into the calipers. I've seen people get nasty brake fluid running down their firewall. BAD!
      05-11-2018, 01:54 PM   #12
cxp213
cxp213's Avatar
313
Drives: M235i
I would recommend that they just bleed out the old fluid in the calipers and top off the reservoir as needed, instead of not bleeding and taking out what's in the reservoir. This allows for fresh fluid all-around and no need to worry about overflow in reservoir.
      05-11-2018, 03:53 PM   #13
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
That shouldn't happen unless it's already overfilled to begin with. Either way the point is that it's a sealed system and the cap should be cracked open while spreading the calipers open.
cxp213313.00
      05-27-2019, 10:07 AM   #14
MerlinMc
114
Drives: 2020 M240i
Shorter video with less fooling around:
Appreciate 2
icin235100.00
jordan24c128.00
      08-08-2019, 10:18 AM   #15
teinesina
Drives: M240xi
is anybody bleeding their brakes every time they swap pads? I feel like the brake pedal on this car is mushy in general and I can’t tell if it’s mushier now that I have done a couple brake pad swaps ( with cracking the reservoir each time)
      08-08-2019, 10:07 PM   #16
John in VA
983
Drives: 2015 228i M Sport
Opening the cap on the reservoir doesn't introduce air into the brake lines. Brake fluid does absorb water over time, so flushing it every 2-3 years is a good idea.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      08-08-2019, 10:17 PM   #17
teinesina
Drives: M240xi
That is music to my ears. I have been stressing out that I have cracked it 3 times in the last month and may have put a ton of air in the system
      07-08-2021, 02:57 AM   #18
imperialgrunt
47
Drives: M240i
Is it really this easy to swap pads on this vehicle? Does this method not require the caliper compression tool? DIY noob here just trying to save myself $1200.
      07-08-2021, 06:44 PM   #19
dradernh
dradernh's Avatar
4352
Drives: 2017 M240i
A claw hammer is a new one on me when it comes to retracting caliper pistons. Looks like one owner made it work, though!
I've used whatever works, most frequently using a screwdriver with a long shaft and a wide blade.
Don't forget to remove your master cylinder's cap before retracting your caliper's pistons. If, before you start, your master cylinder's reservoir is nearly full, you'll want to remove some of the fluid from it so that caliper piston retraction doesn't push enough brake fluid back up the lines to overflow the reservoir.
While there are more sophisticated tools, I've used dedicated turkey basters to reduce the fluid level in brake master cylinder reservoirs. "Dedicated" in the sense that you do not want to hand them back to the wife after they've had brake fluid in them!
I like keeping my calipers' paint unchipped, so I bought Starrett's 5/8" nail punch for driving the pins out: (https://www.starrett.com/metrology/product-detail/800E).
I also bought a small, short hammer at Harbor Freight for tapping the pins back in. However, I've not had occasion to use either of them, so I can't report on how well they work.
My recommendation is to find out what works for you before your pads require replacement. Choose tools that you think will work for you, and practice with them ahead of time so that when the work needs to be done, it's a no-brainer.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
2addicts
