BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > SZL coding & Calibration
      04-27-2018, 03:26 PM   #1
drewhughes
Drives: E91 325D
Hey guys,
Can anyone help me get my used SZL up and running.....ive been searching the internet for hours on end and I'm no further foward...
Trying to do it through Toolset32.
Cheers
Drew
      04-27-2018, 03:49 PM   #2
bfleming
96
Drives: Merc, VW, Porsche, Suzuki
Fire up INPA, get that connected, choose your model, then then hit F2 - Identification.
This will open up a list of your modules. Find your DSC module; read the SGBD group for it - mine was DSC_87.
Close INPA, and open ToolSet32. On the top left, hit the open file, and navigate to the file you found above, e.g. DSC_87.prg. Open that.
Once it loads, a list of commands will open. Assuming it's all in German, you're looking for Lenkwinkel ausgleichen. Double click on that command, and it should run ok for you. Obviously make sure that the car is on a level surface, with the front wheels pointing straight ahead.
HTH
      04-28-2018, 03:47 AM   #3
drewhughes
Drives: E91 325D
Done that yesterday. Didn't work unfortunately
      04-28-2018, 12:44 PM   #4
bfleming
96
Which element of it didn't work? I assume you got all the way into Ediabas & ran the command. What's the underlying issue anyhow?
      04-28-2018, 06:38 PM   #5
drewhughes
Drives: E91 325D
It says it's completed it. but for some reason the fault lights are still present. even after clearing them in INPA
      04-29-2018, 03:15 AM   #6
ptpending
ptpending's Avatar
456
Drives: e91
you need to code dsc module before
and after that initialize dsc steering wheel sensor
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      04-29-2018, 05:38 AM   #7
drewhughes
Drives: E91 325D
Pretty sure ive done that as well, with tool set 32, you put in the arguments thingy box dont you? your 17 digit VIN number followed by 1?
      04-29-2018, 05:56 AM   #8
bfleming
96
There's a DSC calibration sequence in INPA; that won't reset the steering angle sensor on its own though, but it's a good place to start. So the lights are still on - what codes are present? Have you replaced the DSC module or a steering component?
      04-29-2018, 07:17 AM   #9
drewhughes
Drives: E91 325D
I got CC-ID 24, CC-ID 50, CC-ID 354, CC-ID35
      04-29-2018, 07:48 AM   #10
drewhughes
Drives: E91 325D
      04-29-2018, 07:51 AM   #11
drewhughes
Drives: E91 325D
ignore the brake pad one, sensor is shit up
      05-08-2018, 02:57 AM   #12
bfleming
96
Originally Posted by bfleming View Post
There's a DSC calibration sequence in INPA; that won't reset the steering angle sensor on its own though, but it's a good place to start... Have you replaced the DSC module or a steering component?
      05-08-2018, 06:28 AM   #13
drewhughes
Drives: E91 325D
I've replaced the SZL switch unit, thats it
      05-08-2018, 08:36 AM   #14
bfleming
96
OK, is the part number identical to what you had previously? And was it a new or used item?
      05-08-2018, 08:57 AM   #15
drewhughes
Drives: E91 325D
Its a used item but the part numbers are exactly the same
      05-08-2018, 03:10 PM   #16
anees
anees's Avatar
61
Drives: E90 330i Sport
This sounds like a bad steering angle sensor, or even a faulty SZL unit.
The SZL is indirectly calibrated via the DSC module. The steering must be straight, like someone has mentioned above.
Ensure that the cables / connectors to the SZL are plugged in correctly, or
Strip the SZL unit and clean it properly with alcohol. If the steering angle sensor is unable to get a reading on the angle of the steer, the DSC will throw up all sorts of errors.
There's a good wealth of info on the 'my $0.99c steering fix...' or something similar on this forum. Look it up.
      05-09-2018, 10:42 AM   #17
drewhughes
Drives: E91 325D
Ive tried 2 different sensors and SZL units
      05-15-2018, 02:34 PM   #18
anees
anees's Avatar
61
You did not mention why you replaced the szl unit in the first place ? Was something wrong with it ?
The DSC unit has been known to give up the ghost, but generally, you could check other things as well such as the reluctor ring or the ABS sensor, or even both!
      05-16-2018, 09:00 AM   #19
drewhughes
Drives: E91 325D
Ive sorted it now. All good
      05-16-2018, 11:40 AM   #20
anees
anees's Avatar
61
Good to hear, but don't keep us all in suspense.
If you share what your issue was, then I'm sure it could help potential others who experience similar issues. After all, you did post this thread asking for advice.
      05-17-2018, 07:41 AM   #21
drewhughes
Drives: E91 325D
It was my laptop bmw tools not properly communicating with the car, so the coding wasnt working properly.
Solved my uninstalling everything on my laptop and downloading later versions of software
anees61.00
      07-22-2019, 12:34 PM   #22
behenjamin
Drives: E46 M3, E90 320D, MK2 VW GTI
I have this exact same problem. I've tried the INPA configuration and the tool 32 process described exactly as above. But no such luck, any other ideas. When I do the tool32 process it flashes up the ABS light on the dash and off again. But nothing else really happens.
I need help!!!
