Anyone ever seen anything like this before? Bottomed out and broke my jack point
04-23-2018, 08:42 PM | #1 |
93
Rep 541
This sounds retarded, but I somehow bottomed out today and have no idea how. I went to pick my car up at the garage (just had water pump replaced)..
It was in a gravel lot, I went out which I assumed was the exit ramp of the driveway ... and bottomed out BAD ... I figured I went over the curb, and I still might have gone over the curb, however the jack point that got fucked up was on my driver side, and the passenger side would have been the side going over the curb .. so maybe I hit a huge sinkhole? I have no idea. Either way I cracked my side skirt on the bottom, and tore up some of the protective covering underneath the car. I went to look in more detail tonight and my whole jackpoint is just toasted. Here are pics... Anyone ever seen this before? I guess I just have to buy a new jack point? Do they just pop in? |
04-24-2018, 12:01 PM | #3 |
Resident Pedant
503
Rep 792
Yep I took a speed bump at 23.7 mph instead of 23.5 mph and managed to knock mine off. Buy some Rein replacements, they're cheap and easy to install. They do just pop in, the outer plastic legs act as clips. You may need to use some oomph with a hammer or a long screwdriver to remove the old units.
04-24-2018, 11:00 PM | #4 |
Save the manuals!
6016
Rep 6,747
Just buy a new one and push it in... Done
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
zero2sixtyZ951.00 steifan31.50 |
04-28-2018, 06:28 PM | #7 | |
Resident Pedant
503
Rep 792
I noticed they looked way too tall at first, until i installed them. Once they're on the car they're sort of recessed by the undercarriage protection.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
04-29-2018, 01:27 PM | #9 |
32
Rep 76
Did the same while backing off a car lift with my 323Ci E46 (something just nudged it loose). Just plug & play with new one
325i '06, 323Ci '00, A3 2,0TDI Q '10, 740 GLT 16V '88 |
