04-23-2018, 03:32 AM | #1 |
3719
Rep 8,636
Rear LED Lights Coding
Going to fit some replacement clusters, as have a crack in current ones, which are new style LED.
Car is going in to bodyshop for some other bits and was going to get them to swap over the lights while they're at it. As mines pre facelift I will need to code them in. If they can't do I will have to, can it be done before the swap or do I have to wait until fitted? REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed* REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed* REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default] Flashing Rear: REM 3061 FRA_H_L_KALTUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_L_WARMUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_L_IS_LED /aktiv REM 3061 FRA_H_R_KALTUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_R_WARMUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_R_IS_LED /aktiv Reverse lights: REM 3061 RFS_L_KALTUEBERWACHUNG /nicht_aktiv REM 3061 RFS_L_WARMUEBERWACHUNG /nicht_aktiv REM 3061 RFS_L_IS_LED /aktiv REM 3061 RFS_R_KALTUEBERWACHUNG /nicht_aktiv REM 3061 RFS_R_WARMUEBERWACHUNG /nicht_aktiv REM 3061 RFS_R_IS_LED /aktiv Brake lights outside: REM / 3061 / BL_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_L_IS_LED /aktiv REM / 3061 / BL_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_R_IS_LED /aktiv Interior Brake lights: REM / 3061 / BFD_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_L_IS_LED /aktiv REM / 3061 / BFD_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_R_IS_LED /aktiv Rear fog lights REM / 3061 / NSL_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_IS_LED /aktiv REM / 3061 / NSL_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_IS_LED /aktiv Last edited by SkyJawa; 04-23-2018 at 05:27 AM.. |
04-23-2018, 05:10 AM | #2 |
102
Rep 194
I had the LCI rear lights retrofitted to my F31 a week ago at my local dealer and they did the lot. Took them nearly 4 hours mind. But so happy with the result! Best mod I've done
Edit: Sorry, I've just read your OP properly. I thought you were asking if the dealers could code it at all. I'll just crawl back under the stone from whence I came.
Current: 2022 Tesla Model 3 Performance.
Previous: F31 330d M Sport S Drive with ACS Sports Suspension and DMS remap. Remains the best car I've ever owned! |
04-23-2018, 08:18 AM | #5 |
3719
Rep 8,636
