335i brake upgrade: M3 vs. F30 M Performance
04-18-2018, 02:33 PM | #1 |
58
Rep 192
I tried searching but couldn't find this specific topic. Which of these upgrades to a 335i gives better braking power? (Note, mine's an E90). I will be upgrading to the M3 Master Cylinder regardless of route.
-M3 Brakes (In this case I'lll be upgrading to M3 rear axles + diff, so this'll plug right on) -F30 M Performance Brakes Thanks ahead of time. |
04-18-2018, 02:56 PM | #3 | |
4276
Rep 9,206
Wrong! None M 34116773201 vs M3 34112283361 Only pads are interchangeable. |
IllSic_Design2124.00 |
04-18-2018, 03:05 PM | #4 |
2124
Rep 2,758
Whoops, they look exactly the same, didn't realize they had different specs. Thanks for the info.
04-18-2018, 03:13 PM | #5 | |
4276
Rep 9,206
M3 caliper has larger piston thus the larger brake cylinder and also the carrier has different spacing, the bolts won't line up in addition. |
04-18-2018, 03:26 PM | #6 | |
2124
Rep 2,758
04-18-2018, 03:46 PM | #7 | |
58
Rep 192
I was going to replace the uprights too. Any advantage in handling if doing so anyway? I'll probably go the F30 M Performance route then based on braking power (bonus for how it looks too). Time to search if they fit the M3 rear axles. |
04-18-2018, 04:28 PM | #8 | |
4276
Rep 9,206
F30 fit the E9x M3 rear but you will need M rotors witch will be bigger than the front rotors so I don't recommend you going that route |
04-18-2018, 05:01 PM | #9 | |
58
Rep 192
I'll replace a full set of calipers and rotors, front and rear. Why do you recommend against this? |
04-18-2018, 08:06 PM | #10 |
4276
Rep 9,206
Yes you can swap the rear control arms and have m3 upright with none m3 control but that is giving away the single benefit from having m3 components in the rear. I'm against because F30 won't mount on E9x M3 front upright. Only on none M. So if you go with rear M3 E9x upright and F30 brakes you will need to use F82 rear rotor that will be bigger than your front. All of this has been covered on the F30 brakes thread.
04-20-2018, 04:50 PM | #11 | |
58
Rep 192
04-20-2018, 05:05 PM | #12 |
729
Rep 1,815
As much hard driving I do in my 335i I have to wonder why you would ever need to go with anything else than stock. Stock brakes are more than capable of stopping my 335i from speeds in excess of 185mph on the autobahn. If you have no confidance in the stock parts than you are running substandard replacement parts.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
04-20-2018, 05:16 PM | #13 | |
58
Rep 192
I've yet to track this car, but would like to slowly set it up for tracking. Because of the modifications I'm planning for the car, I can easily swap to M3 brakes, but noticed the M-Performance ones are nicer looking, and am now learning they are even better. So in short, I'd like to upgrade my brakes to handle higher horsepower, to be better on a track, and it's simply a bonus if it looks nicer. |
04-20-2018, 06:12 PM | #14 | ||
4276
Rep 9,206
04-21-2018, 08:01 AM | #15 |
729
Rep 1,815
Speed is never the sole factor, repetition, speed, condition of the equipment, condition /traction of the tires, road surface...
04-23-2018, 03:18 PM | #16 | |
453
Rep 2,973
Go F30.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
feuer4275.50 |
