04-12-2018, 04:06 AM | #1 |
901
Rep 1,801
Sports dials - accurate or gimmick
I'm just wondering if anyone knows how these are calculated.
Are they accurate or just looking at a known maximum for the car and it knows to calculate back based on that? I happen to have a couple of old videos with the dials displayed and I've taken a guess at the readings on them. They tie in rather well with what BMW claim as the max so I'd guess they are just set to max when the accelerator is at 100% Pre MPPSK 335bhp / 445nm (at a really bad guess) 326bhp / 450nm (bmw) Post MPPSK 365bhp / 510nm (at a guess) 360bhp / 500nm (bmw) |
04-12-2018, 04:21 AM | #3 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
Gimmick. Torque measuring devices suitable for fitting to vehicles exist but they are very expensive. Your car doesn't have one.
04-12-2018, 04:26 AM | #4 |
901
Rep 1,801
Do we know if its based on % of throttle or something else like the Torque app that measures acceleration VS weight of car and drag coef? If I floor it downhill will I get a higher reading than it should or will it just max out at the pre defined value?
04-12-2018, 06:00 AM | #5 |
3610
Rep 4,518
I believe it just maxes out at a predefined value. My guess would be that it looks up a figure based on throttle position, boost pressure etc and possibly refers to actual figures from dyno testing of a development model. I'm not saying it's inaccurate, just that it's probably not actively measuring what your car is making.
04-12-2018, 06:28 AM | #6 | |
636
Rep 968
chris-c900.50 |
04-12-2018, 06:31 AM | #7 | |
3489
Rep 9,709
I imagine it works off the hot-film mass airflow sensor, which with revs you can approximate into power/torque reasonably accurately. Although probably adjusted to a known full scale, rather than blindly trusting a mass produced sensors readings. |
F30Andy1778.50 |
04-12-2018, 06:34 AM | #8 | |
901
Rep 1,801
I might have to go for a spin later uphill then downhill and see if it shows a different reading. |
04-12-2018, 07:02 AM | #9 |
824
Rep 1,912
Total waste of a feature, crap IMO
Happy Motoring
Evdok |
....,,,,..,,..6734.00 |
04-12-2018, 09:47 AM | #11 | |
1882
Rep 7,000
To be fair she thinks I am a saddo for lots of other reason too |
04-12-2018, 05:38 PM | #13 |
3105
Rep 7,033
Drives: 335xd Msport +
Makes a decent enough screen saver.
04-12-2018, 08:34 PM | #14 |
1633
Rep 2,282
I had mine set to hot key/radio key 6 for fun.
The novelty has worn off though now. Thought it was top dog when I got the car
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
04-13-2018, 02:37 AM | #16 |
1364
Rep 2,495
Well there is no dyno in the car
Total gimmick and just based on throttle and revs.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
04-13-2018, 05:55 PM | #19 |
261
Rep 548
That sounds really interesting ...... Could you enlighten further please?
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
04-13-2018, 06:09 PM | #20 | |
1780
Rep 2,029
I have OBDLink LX running and the set up allows you to input factors such as frontal area, specific mass, Cd and wheel diameter as well as the usual stuff. Changing these parameters affects the bhp and torque values displayed. I datum'd mine on my last dyno run. The peak torque and bhp pretty much matches what I got on the dyno (recorded the runs on there as well as interpolating the graphs). I'm fairly confident that what I'm seeing on OBDLink LX is accurate to within 2-3%. Throwing up the 'sport dials', I'm seeing similar figures (up to their max calibrated values; standard 435d figures, despite a stage 1 remap). They do saturate out at the default figures but their values across the range seem to be quite accurate. So bearing that in mind, I think what is displayed on the dials is as near as 'technically' possible and isn't just a throttle position and revs output. |
04-14-2018, 03:34 AM | #21 |
200
Rep 542
Speedometer accuracy within British regulations is -0% to +10%
Calculated from roadwheel rotational speed and diameter. The display is affected of course, by fitted tyre size and how worn they are. MPG is calculated from fuel injector parameters. Injectors have a specified fuel flow rate, at specific pressures. Consumption is a calculation of injector timing and measured rail pressure. Distance error is also subject to speedometer calculation. Often seen typically within 2mpg of calculated figures, when in the order of 40mpg. IE. 5% Engine torque is calculated from fuel flow and a function of engine rpm. There is no reason why the manufacturers function, specific to each engine model, should not be accurate. Affected by the energy density of the fuel used (diesel / petrol / air) Engine horsepower is a linear function of Torque(Nm) x engine RPM x 9549 So 5% shouldn't be difficult to achieve, unless it's a well worn engine. Probably far more accurate than a lot of rolling road dynamometers guess at engine HP.
335d xDrive
04-14-2018, 07:30 AM | #22 | |
62
Rep 163
Darth Helmut1780.00 |
