04-11-2018, 12:54 PM | #1 |
151
Rep 475
Rev Matching
I'm currently still in the 1st week of waiting after placing my order on a new M240i, and been reading up as much as I can on the car. I'm wondering how this rev-matching feature behaves. How does the car know if you are going to downshift? I found something where if you're in 3rd and going to 2nd, it will blip the throttle as soon as you move the shifter to the left. What I'm curious about is what about going from 4th to 5th just as part of normal driving (shift around 3k or so). Does it ever get confused and think you are downshifting to 3rd and blip the throttle?
18' F22 M240i | 6MT | MGM/CR
02' E46 325i | 5MT | SBM/B (beater - 200k+) 10' E82 135i | 6MT | BSM/CR (sold) 03' E46 330ci | 5MT | JB/B (sold) |
04-11-2018, 02:45 PM | #2 |
Rep 13
Also waiting on my manual m240i. From what I've read it happens when you start to push into the gear so it does have correct info available and it happens quite quickly. I experienced this myself briefly testing a manual 340i, it was rather pleasant. Can't wait to experience it in my own car.
04-11-2018, 02:50 PM | #3 | |
151
Rep 475
04-11-2018, 03:25 PM | #4 |
630
Rep 1,227
I have a 6MT M240i. The revmatching feature works shockingly well. I don't know how else to describe it other than "it just works.... flawlessly.... all the time".
As others have alluded to, the sensors are in each gate which is how the system knows if you are going say 5th->4th vs. 5th->3rd. You can blip the throttle yourself as long as you do it before entering the gate of the new gear.
Raptor0120.00 |
04-11-2018, 04:01 PM | #5 |
558
Rep 594
Right from dealerspeed just for you!
“Rev matching” is BMW’s new term for this function; we have included it in all of our automatic and double-clutch 1 transmissions for some time. Now, BMW M has added the feature to its manual transmissions. As the driver moves the shift lever (again as an example) from 4th to 3rd, the electronic engine-management system brings up the engine speed and holds it as the driver engages 3rd. As far as smoothness is concerned, the result is essentially as with traditional double-clutching, but the driver doesn’t have to bring so much skill to the process (the shift "pause" in neutral can be eliminated allowing for extremely fast and smooth down shifts). Finally, as a nod to tradition, if the Sport+ mode has been selected, the rev-matching function is de-activated and the skillful driver can still practice his or her skill. Though we chose the 4-3 shift for the explanation, all this applies to any downshift: 6th to 5th, 5th to 4th, 2nd to 1st, also if gears are jumped, etc. BMW’s rev matching also functions on upshifts (such as 2nd to 3rd, etc.). The engine speed is reduced to match the optimum speed for the higher gear selected resulting in optimized upshifts in all driving situations. |
04-11-2018, 04:08 PM | #6 | |
151
Rep 475
Basically, do I need to alter my shifting to be able to drive this thing smoothly? Obviously no more need to heel-toe, but other than that???
04-11-2018, 04:12 PM | #7 | |
558
Rep 594
Clutch in, into neutral, off power, into gear clutch out, back on power. But I drive a 72 HP beetle manual. so...I got time between shifts |
04-11-2018, 04:15 PM | #8 |
151
Rep 475
Yeah I guess its kind of all happening simultaneously. I made it sound like it takes me 3 seconds to shift lol. I will have to just wait and try it all out on my own. Wait is killing me and it's only been 4 days since I sold my 135i
04-11-2018, 07:37 PM | #9 |
987
Rep 1,241
A few threads worth reading:
http://www.2addicts.com/forums/showthread.php?t=1338339 https://f87.bimmerpost.com/forums/sh....php?t=1471482 I had my m240i out again yesterday and the only time it consistently auto-blips is when doing a sequential downshift from any gear i.e. 4th >> 3rd or 6th >> 5th. I believe I also caught it rev matching when I was doing a neutral roll and then went right back into 5th gear to continue cruising. However, when I did a neutral roll and wanted to go into 2nd as I was approaching a stop sign, it did not auto-blip when I was expecting it to and I got some head jerk as a result. Seems there is still some sort of inconsistency or bug/software update that is causing the unpredictable auto-blipping. Very annoying. I hope BMW gets this fixed soon with a software update. For now, I'm going to have to call my local BMW service department and see if they have any insight. The pedal positioning in the F22 platform is superb, so heel and toe is much easier than I experienced with my 2007 Carrera S or 2016 WRX. Almost wish I could code it out completely at this point until BMW resolves the inconsistency. I found myself wanting to heel and toe anyhow...
CP911
04-11-2018, 09:51 PM | #10 |
Ring Leader of G8X Haters
25085
Rep 8,762
Don't know if anyone has replied with this yet, but if you don't like the rev matching, i believe whenever its in sport + (just sport without traction control), it disables the auto rev match.
I believe it also does this whenever the traction control is off (doesn't matter which drive mode) but i am not completely sure about this one. |
04-12-2018, 01:10 AM | #11 | |
630
Rep 1,227
04-12-2018, 07:24 AM | #13 | |
151
Rep 475
04-12-2018, 10:19 AM | #15 |
151
Rep 475
CP911 Those posts just made me even less excited for rev-matching... dang it. Ha. What happens if you just blip the throttle or heel-toe on your own, even with rev-matching on? If the computer's purpose is to match the revs, would it either ignore your manual input, or cancel the auto input, or some combination of both?
04-12-2018, 11:18 AM | #16 |
Car Geek
3629
Rep 3,598
Computer adjusts the revs dependent on your input, so full throttle blipping can be done, it just adjusts the revs to match the road speed after you have blipped, as you will blip the throttle before fully leaving the previous gear, it will only adjust going into the next gear.
04-12-2018, 07:29 PM | #17 |
38
Rep 66
Drives: 2018 M240i
On my 2018 M240i, I only seem to get rev matching on my first downshift. For example, if I'm going from 6th to 5th it will rev match, but then when I downshift from 5th to 4th it doesn't. I think others have experienced this as well; anyone else see this? Seems like you should either have rev matching for all downshifts or none at all.
04-12-2018, 07:39 PM | #18 |
15
Rep 55
my M240 rev matches on all downshifts except when I engage the clutch, shift down 1 and shift down 2 before releasing the clutch. It also has some kind of time delay that if you exceed it wont rev match. But quick downshifts are always matched.
I've really grown to like it. |
04-12-2018, 09:11 PM | #19 | |
130
Rep 832
04-13-2018, 07:24 AM | #20 | |
151
Rep 475
04-13-2018, 12:40 PM | #21 | |
130
Rep 832
I can't imagine why in hell you would want rev matching on upshifts. I assume the goal is to hold rpms at an optimal point for the next gear but wholly heck, if someone upshifts so slow as to allow the rpms to drop down enough for it to be even a tiny issue in going to the next gear, they should not be driving a manual! Guess I will be driving with DSC off a lot! |
