04-11-2018, 10:53 AM | #1 |
19
Rep 39
Melted spoiler exhaust
After the first track day, I noticed that the exhaust has melted the plastic spoiler. I did get the Dinan resonator delete that might have heated things over stock. I just bought a carbon fiber diffuser and don't want to melt it as well. I measured 1" from the top of the exhaust to the molding.
Can someone throw a tape on theirs and let me know what you have? It's a 17 M240i Thanks, rickd
2017 M240i - BM3 Stage 2+ tune - Millway Camber plates - Dinan Midpipe - Dinan Intake - Wavetrac Diff - Bilstein B16 coilovers - Apex EC8's - Spool Ethanol sensor - TU Pump - Spec Stage 2+ clutch - E30 map - AutoTechnic Carbon fiber Trunk spoiler - RW Carbon diffuser - Front lip spoiler - Mirror caps.
04-12-2018, 07:17 AM | #2 |
250
Rep 281
I’ve had the same problem. After a few track days, my m perf diffuser is melted where the tips were curling up. You could tack weld the pieces together so there’s less movement. I have an aftermarket exhaust so the tips are adjustable, I angle them down a little bit.
04-12-2018, 09:22 AM | #3 |
313
Rep 525
How is the diffuser and the exhaust tip making contact? Is the stock (or MP) diffuser is catching air and being pressed onto the exhaust tip which then melts due to heat?
04-12-2018, 11:00 AM | #4 | |
19
Rep 39
I'm going to see if there is a way to angle it down like capt_and mentioned. I don't see how because the rubber hanger isn't adjustable?
04-12-2018, 11:05 AM | #5 |
5556
Rep 5,373
There's definitely contact going on. When you drive hard and shift hard (especially in the 6MT), there will be a lot of movement of the motor and exhaust. Remember, all those components are sitting on, supported, and otherwise hanging from rubber mounts and hangers.
Does the Dinan midpipe remove OEM flex section? That certainly won't help things if it does. Also, the reduced weight of the Dinan midpipe and muffler may actually contribute to even more exhaust system movement.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
Dylan861330.00 |
04-12-2018, 11:44 AM | #6 | |
19
Rep 39
Got it installed this morning!
04-12-2018, 01:49 PM | #7 |
1330
Rep 2,214
That's from rubbing and contact with high heat, this wouldn't happen from simply exhaust temps. You can see where the pipe has melted into the diffuser, and made a lasting "impression"..
You'd be surprised how much the factory exhaust can move.
04-16-2018, 08:48 AM | #10 |
250
Rep 281
For whatever reason, whenever the exhaust gets heated up (track temps not highway temps), the tips curl up. I have a picture of my car going down a straight with the right tip clearly higher than the left and touching the diffuser.
