04-10-2018, 09:24 PM | #1 |
97
Rep 130
M Performance Rotors.
Hi guys. Please do give some advise on this. I'm currently on M Performance Brake for my F30 330i and the rotors is about time to replace them. Is there any aftermarket disc which are better than the stock ones?
04-10-2018, 10:08 PM | #2 |
398
Rep 732
The factory ones are 2 piece design (hub is aluminum) and most aftermarket ones are a one piece design (full iron) that's heavier.
So far I have only seen the following that's a 2 piece design like the BMW ones: PAGID 355120781 rear slotted and dimpled 345mm PAGID 355120811 rear blank 345mm PAGID 355120771 front slotted and simpled 370mm PAGID 355120831 front blank 370mm They are cheaper than factory rotors and I think they might be the OE supplier to BMW. You can find these on ebay or rockauto. |
kern4174449.50 |
04-10-2018, 11:28 PM | #3 |
246
Rep 483
04-10-2018, 11:32 PM | #4 | |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
For lighter options Stoptech has the AeroRotor Kit (ARK), and ECS has a two-piece too. Both options are supposed to save 2lbs/rotor (for the 370mm variant). I haven't seen any other styles for the rear rotors. I have the ARK front rotors (slotted variant). No complaints so far. |
04-11-2018, 06:49 PM | #5 | |
398
Rep 732
06-15-2018, 03:30 AM | #6 | |
Rep 8
ECS M-Sport two piece rotors
Perhaps too many drills/slots to be a great braking surface, but certainly much lighter than OEM. |
Genieman245.50 |
06-15-2018, 04:17 AM | #7 |
No 55mph
1622
Rep 8,476
I also use the ECSTuning 2-pc 370mm rotors as above - & I see they just increased the pricing on them, they were <$800 not too long ago...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-17-2018, 12:15 PM | #9 |
103
Rep 285
Drives: 2014 428i XDrive
06-17-2018, 12:53 PM | #10 | |
1610
Rep 3,947
06-18-2018, 09:06 AM | #12 |
4517
Rep 8,942
I've been told stop tech is better and lower price as well.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
