04-10-2018, 04:46 PM | #1 |
2472
Rep 4,653
Slight dampness in headlights
Hi what's the issue and fix?
I've got a slight layer of condensation inside my headlights.
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
04-10-2018, 04:56 PM | #2 |
1881
Rep 3,433
Just about every car I have had with sealed lighting units with plastic fronts has had this over the last 15 years or so... to some extent... and it seems to come and go with the seasons... reducing in warmer weather...
Not sure what causes it other than (i guess) slight air leaks causing moisture in the warmer air in light to condense on the inside of the cool front element... Even if you change the units, it can still happen... I also had it in rear light units..
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
04-11-2018, 03:31 AM | #5 |
6431
Rep 8,504
The large access cap on the rear of the headlight unit (accessed through the wheel arch liners) are water resistant but not watertight. The hairdryer approach would work, or just leave the access caps off on a warm day with the car facing the sun.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
04-11-2018, 03:43 AM | #6 | |
Jeff
318
Rep 1,451
An alternative, or addition, is to keep the headlights on full for a few days. Mine was so bad, I actually took it into the dealer to see if I could get it replaced. |
04-11-2018, 04:21 AM | #7 |
1402
Rep 8,088
Keeping headlights on will only dry them out if you have halogen headlights; LEDs and Xenons do not get hot at the front.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
04-11-2018, 04:23 AM | #8 |
Jeff
318
Rep 1,451
04-11-2018, 08:13 AM | #10 |
6431
Rep 8,504
I was going to suggest the exact same thing, then thought they might be a fire risk if left in and headlights were on
04-11-2018, 02:56 PM | #11 |
25
Rep 24
This is what I did back in February on a rare sunny afternoon and the condensation hasn’t returned:
- warm sunny day. Park car with front facing the sunlight. - lift bonnet, unscrew the caps on the 2 headlamp units and leave them aside. - drop bonnet but leave it off the latch. - go and have a cuppa. 20-25 mins later, they’ll have dried out. Put the caps back on. Job done. |
04-11-2018, 03:30 PM | #12 | |
3489
Rep 9,709
04-11-2018, 03:43 PM | #13 |
759
Rep 1,863
The units aren’t hermetically sealed. There are removable access covers and moisture will get sucked in when the temperature changes
To avoid condensation, they need to be hermetically sealed otherwise any moisture in the unit at point of manufacture while condensate as the temperature drops Water ingress is a different issue. If you have that there is a leak. |
Alice Coupe156.50 |
04-11-2018, 04:08 PM | #14 | ||
6431
Rep 8,504
04-11-2018, 11:08 PM | #15 |
13362
Rep 7,484
04-12-2018, 05:30 AM | #16 | |
680
Rep 2,445
Drives: 2018 630iGT sport
As noted above, it's condensation and, unfortunately, is normal - particularly on the front because of this:
You can take the covers off the back of the headlight, heat up the headlights from the front with a hairdryer and leave it overnight (with the covers off) to cool down and temparatures stabilise. This will cure it temporarily. Sometimes you can get lucky and have a cool and dry night, and you might get all the moisture in the headlight air out, but chances are you'll have to repeat the procedure a few times. Rear lights, you can't do anything about it. I had quite a lot of visible water droplets formed in mine after the car was about a year old, and had both lights replaced under warranty with no quibble. New ones dont' seem to have developed any similar problems yet, and we've been through a pretty cold and damp winter this year. Al I had was a very small amount of condensation vapour on one or 2 days, but that's been it. |
