04-10-2018, 01:45 AM | #1 |
105
Rep 265
Brake pads without wear sensor?
Hi,
Just bought Zimmermann drilled rotors for my BMW F30 328i and TRW Dtec Ceramic brake pads. Problem is that only the front pads have the wear sensor fitting, the rear is missing this. Is it possible to just unplug the rear sensor connector without getting any error codes? The sensor is not worn down, so worst case I can keep it in the wheel well with a zip tie. I would go with ATE Ceramic brake pads if I could, but the seller told me TRW where the only ones recommended for drilled rotors. Thank you! |
04-10-2018, 10:55 AM | #2 | ||
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
That doesn't sound correct. You should be able to use any pads. |
04-10-2018, 01:54 PM | #3 |
A family of bimmers
2747
Rep 7,742
The pads should have a location for the pad sensor if they are meant for your car. are you sure they didnt send you incorrect pads?
If you wanted to you could also cut the sensor and wire nut the two wires in the sensor to complete the circuit thus eliminating a brake warning light.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
