BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > E90 Performance Suspension first impressions
      04-09-2018, 01:45 PM   #1
Phyrexia
Resident Pedant
503
Drives: '15 335i 8AT
Got the PS installed yesterday afternoon, much to my delight. I've logged many hours working on my cars but this was actually the first suspension install I've ever done.
The installation was pretty straightforward. The forum was helpful, as always, and the BavAuto videos are nice resources.
I was coming from the standard suspension and I've never driven an E90 with the sport suspension.
The car feels much more planted. Side to side roll has been greatly decreased as expected. The car doesn't pitch forward as much under braking.
I've found a couple of real SOB bumps on the 405 and on PCH and where I thought I was about to bounce off into space, I feel very firmly attached to the road.
It reminds me of my E46 M3 right when I bought it, with a little more comfort. Compared to the E92 M3 with the adjustable suspension I once drove,
the Performance Suspension is more comfortable, less bumpy.
I wasn't sure exactly what to expect - I wanted to keep some of the comfort, but my driving style does not mesh well with the standard suspension and I knew I would sacrifice some of that.
While I can feel the road more (still on RFTs for a few more weeks) I don't feel like the car is too bumpy. Once I switch to some Indy 500s I may find myself even more pleased.
So far, so good. I'm noticing at first glance there's more wheel gap up front than in the rear. I thought the front would be a smidge lower. I suppose the strut bearings will settle down a touch.
I've got about 30 miles on the suspension so far.
I'll take some more pictures later this afternoon when the lighting is the same.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
Appreciate 2
feuer4275.50
Jklad421.00
      04-09-2018, 01:55 PM   #2
feuer
feuer's Avatar
4276
Drives: wife crazy!
Did you loosen up the control arms and torqued them back down at the current ride height?
Appreciate 2
Phyrexia502.50
Volasko705.00
      04-09-2018, 02:09 PM   #3
Phyrexia
Resident Pedant
503
Yes, as best I could. I was able to torque down the "radius rod" bolt (the forward arm) with the car completely on the ground, though now that I think about it, I didn't roll the car at all to get the suspension to fully settle.
For the "wishbone", I jacked up the knuckle until right before it lifted the car off the jack stands, put a wrench and impact on the nut and bolt, tightened them down. For that matter...can those control arm bolts be torqued down too hard? I got them pretty good with an 18v impact.
Do you think it would be worth it to buy a set of ramps, pull up on them, loosen the fasteners, and tighten them back down? I'd considered doing that last night. And have been meaning to get a set of ramps for my girlfriend's car's oil changes.
feuer4275.50
      04-09-2018, 02:23 PM   #4
feuer
feuer's Avatar
4276
Drives: wife crazy!
For the "wishbone", I jacked up the knuckle until right before it lifted the car off the jack stands, put a wrench and impact on the nut and bolt, tightened them down. For that matter...can those control arm bolts be torqued down too hard? I got them pretty good with a battery impact.
I think you should do it considering that your are doing this yourself and you care about how the car rides and how the suspension will perform. I don't have the exact torque values but battery impact should be sufficient. You need to do it on both front arms and all five in the rear for best results and longevity on the bushings. Is a lot of work. Something that most people that are DIY this and shops a like, won't do.
Phyrexia502.50
      04-09-2018, 02:32 PM   #5
Phyrexia
Resident Pedant
503
I certainly want it to be correct. I just wondered if my process was good enough. I'll give the ramps a shot and see how it goes.
feuer4275.50
      04-09-2018, 02:40 PM   #6
david in germany
729
Drives: 118i, 335i and 328i
Also give it a few weeks to settle. I love my PS on my 335i!
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
Appreciate 2
feuer4275.50
Phyrexia502.50
      04-09-2018, 02:44 PM   #7
feuer
feuer's Avatar
4276
Drives: wife crazy!
I only have the PS springs on my 335i matched with Yellow Koni's. It has been 4 years since I installed them. Drastically better than the OEM Sport springs.
Phyrexia502.50
      04-09-2018, 02:53 PM   #8
david in germany
729
Good mix as well. On my e87 I am running the PS springs with Bilstein B8's a lot of off ramps I rarely slow down for anymore.
      04-09-2018, 06:09 PM   #9
Phyrexia
Resident Pedant
503
Do you or does anyone know who is manufacturing these dampers for BMW? Are they Sachs? My kit didn't have any part numbers for replacement dampers included.
I think the car may have settled already since I took the first pictures. I'm going to report back in a few days/hundo miles. Still going to rejigger the bolts, feuer.
feuer4275.50
      04-10-2018, 08:09 AM   #10
feuer
feuer's Avatar
4276
Drives: wife crazy!
Sachs make the dampers.
Phyrexia502.50
      04-10-2018, 04:01 PM   #11
AWSB328iM
AWSB328iM's Avatar
397
Drives: 2011 E92 328i M-Sport 6MT
My 2011 E92 M-Sport has 71k Miles. Thinking about going with the full Performance Suspension, new strut mounts, Monroe rear mounts, and M3 control arms around 80k Miles. My Pilot Super Sports are almost worn out and I plan to swap them for PS4S this summer/fall.
      04-10-2018, 04:09 PM   #12
Phyrexia
Resident Pedant
503
We're in the same boat. My car has 73500 mi on it. I'm not sure if I'm going to get M3 arms. And I need new tires. I bought Lemforder rear mounts though. I've read negative things about Monroe here.
      04-10-2018, 04:45 PM   #13
Zaíne92
Drives: Alpina White 325i E92 '06
I'm thinking going the ps spring route pairing them with bilstein b4 is it good combo?
      04-10-2018, 05:15 PM   #14
feuer
feuer's Avatar
4276
Drives: wife crazy!
I would not know. Sorry. In the past 12 years I have had 3 vehicles and used Koni yellows exclusively.
      04-10-2018, 05:31 PM   #15
Jklad
Jklad's Avatar
421
Drives: 2007 335i Coupe
I think I would be all for this kit except for the fact that your forced to buy the sway bar. Feedback from another user who bought this kit was that The sway bar that comes with it essentially sucks and that he got a large noticeable improvement simply from swapping out the sway bar for a 28in e93 m3 bar.
2007 E92 335i MT
Phyrexia502.50
      04-10-2018, 05:58 PM   #16
Phyrexia
Resident Pedant
503
Maybe it's unimpressive coming from the Sport package, but I can tell a giant improvement in body roll coming from the standard suspension. I'm not sure what I'd gain with a 28mm bar. The PS bar is 26.5 I think?
I forgot to mention that the skinnier sway bar bushings that come preinstalled with the included swaybar were the correct ones for my car. My car had the skinnier brackets already. So huzzah for that.
Jklad421.00
      04-11-2018, 03:26 PM   #17
Phyrexia
Resident Pedant
503
And I am glad I followed your advice instead of just trying to let the car settle. My ramps came in and I:
  • Pulled the car upon the ramps,
  • Unbolted enough of the undershield for access,
  • Loosened the four front control arm fasteners,
  • Zip tied the undershield,
  • Backed off the ramps,
  • Moved the car a couple feet backwards and forwards while turning the steering wheel to settle the suspension,
  • Pulled back up on the ramps,
  • Removed zip tie,
  • Tightened the four front arm fasteners,
  • Replaced the undershield,
and now the front end of the car is immediately and noticeably lower. This is more along the lines of what I was expecting. Going to wash the car and post more pics tonight.
Appreciate 3
feuer4275.50
Jklad421.00
AWSB328iM397.00
      04-11-2018, 04:02 PM   #18
Phyrexia
Resident Pedant
503
Also, because I am a nerd, I determined that doing this with ramps is no problem - my ramps lift the wheels 6.25", so the struts are at an 86.7 degree angle with respect to the ground, so (assuming perfect initial caster) the front suspension is receiving 99.8% of the weight it would if you were to do this on a totally flat surface (like with a pit, or a fancy drive-on lift).
      04-11-2018, 10:17 PM   #19
AWSB328iM
AWSB328iM's Avatar
397
  • Removed zip tie,
Waiting for pictures!
      04-11-2018, 10:20 PM   #20
AWSB328iM
AWSB328iM's Avatar
397
What did you read negative about the rubber Monroe mounts? I haven't looked in about a year, but they were the rage then compared to the $100+ Dinan mounts.
Phyrexia502.50
      04-11-2018, 11:34 PM   #21
Phyrexia
Resident Pedant
503
Some clouds moved in and by the time they moved away my house was blocking the sun for The Perfect Shot. I did wash it though, I had almost forgotten why they call this color Titanium Silver
I'll see if I can find my source for Monroe negativity. Take it as apocryphal until then. Edit, I found the thread I was thinking of, and my wires are crossed. They say the Monroes transmit more NVH but that's not necessarily a bad thing. It was not what I was going for.
      04-19-2018, 06:46 PM   #22
Phyrexia
Resident Pedant
503
Here we are. I'm happy. Drives great. I still need an alignment but I still need tires too so I'm waiting a few weeks.
Biginboca3763.50
