Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > List of Coilovers under $1500 and their features
      04-07-2018, 02:32 PM   #1
Blueeyesredpanda
Blueeyesredpanda's Avatar
401
Drives: E90 / F30
I am new to coilovers, I summarized the list of coilovers which is under $1500usd and I would like to add the features to the list (e.g. adjustable damping etc)
Not completed yet but feel free to comment below i will add it to the list
Stock 328i LCI xdrive Spring rate:
Front -2.5k (kg/mm) = 140 lb/in
Rear - 8k (kg/mm) = 448 lb/in
__________________________________________________
Spring rate conversion:
2k (kg/mm) = 112 lb/in
3k (kg/mm) = 168 lb/in
4k (kg/mm) = 224 lb/in
5k (kg/mm) = 280 lb/in
6k (kg/mm) = 336 lb/in
7k (kg/mm) = 392 lb/in
9k (kg/mm) = 504 lb/in
10k (kg/mm) = 560 lb/in
11k (kg/mm) = 616 lb/in
12k (kg/mm) = 672 lb/in
Sonic Tuning Coilovers
$899
http://www.sonictuning.com/bmw-3-sei...uspension.html
Features:
-Height adjustment
-Adjustable Damping
-Adjustable Preload
Cons:
-Does not get very low
-OEM struct bar needs spacer
Godspeed
$900
https://godspeedproject.com/bmw-3-se...overs-awd.html
Features:
-Height adjustment
-Adjustable Damping
Spring rate:
Front: 14kg/mm Rear: 9kg/mm
Cons:
No reviews
ISC Coilovers
$984
http://iscsuspension-na.com/bmw-susp...egory=12617117
Features:
-32 step height adjustment
-Adjustable Damping
BC coilovers
$995
https://bcracingcoilovers.com/produc...cing-coilovers
Features:
-Height adjustment
-Adjustable Damping
Spring Rate:
Front 6kg, Rear 12kg
Cons:
Clunk noise
ST v1 (Made by KW)
$1019
http://www.stsuspensions.com/product...kit-90902.html
Features:
-Height adjustment only
Cons:
Not stainless steel (not a problem in Hot climate region)
Silvers NEOMAX
$1095
https://silvers-na.com/product/silve...cyl-2006-2011/
Features:
-Height adjustment
-Adjustable Damping
Spring rate: Front 14k, Rear 9k
H&R
$1175
https://topgearsolutions.com/h-r-per...free-shipping/
Features:
-Height adjustment only (Front Lowering: 1.25 - 2.5in, Rear Lowering: 0.75 - 2.0in)
Fortune Auto 500 Coilovers (Made by Broadway Statics)
$1375
http://www.fortuneautosuperstore.com...i-e90-e91-e92/
Features:
-Height adjustment
-Adjustable Damping
Spring rate: Front 8k, Rear 11k
Kw v1
$1444
http://www.kwsuspensions.com/product...-10220048.html
Features:
Height adjustment only (Front Lowering: 0.6" to 1.8", Rear Lowering: 0.6" to 1.6")
Cons:
$Most expensive and lack of damping adjustment
http://norwestsuspension.com/convert-spring-rates
Last edited by Blueeyesredpanda; 09-24-2018 at 01:58 PM.. Reason: updating the list
Appreciate 4
      04-09-2018, 09:39 AM   #2
HooDat
31
Drives: e92 335xi 2008 | c63s amg 2019
Thanks for the list i've been trying to decide between KWv1s and FA500s. The FA500s come with camber plates. and I believe the FA500s also cannot use the stock strut bars without modification... If i remember correctly there is a clearance issue.
2008 | e92 | 335xi | 6MT | VRSF FMIC| VRSF DPs | VRSF CP | S&B DCI | FORGE DV | MHD Tune | BMW PE
2019 | w205 | C63s AMG
      04-09-2018, 01:53 PM   #3
Blueeyesredpanda
401
Drives: E90 / F30
Same here, St V1 or FA500 or BC
      04-09-2018, 02:22 PM   #4
Blueeyesredpanda
401
Drives: E90 / F30
Doesn't this apply to all the ones with damping adjustment? I even have BMW Performance struct bar... dont know what to do
      04-09-2018, 02:42 PM   #5
HooDat
31
not sure if it's all the ones with the damping adjustment. I just know FAs damping knob gets in the way and people had to run either the m3 strut bars or had to add some sort of spacer... anyone with FA500s that can clarify?
      04-09-2018, 04:07 PM   #6
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Thanks for the back link. We also do additional 10% off ST and KW with the use of our add to cart discounts - just create an an account on our site and add to cart for discounts to appear.
      04-09-2018, 04:11 PM   #7
Blueeyesredpanda
401
Drives: E90 / F30
Additional 10% off this price $1,019.99 for ST V1 ?
      04-09-2018, 04:14 PM   #8
3441
Yes sir but we really can't talk about pricing unless we are in a classified section of the forums or private messaging or we can get in trouble.
      04-09-2018, 04:27 PM   #9
eetadik
23
Drives: Noneya
ST's are honestly a joke nowadays compared to what else is out there. You're paying for a name with a very weak feature set. For instance, the height adjustment is done through spring preload...not a fully threaded shock body. Game changer? Hardly. Overpriced and behind the times? You bet. Additionally, a lot of ST kits do not come with top mounts, let alone adjustable camber plates, so you can add those to your lil' cart too.
      04-09-2018, 11:11 PM   #10
HooDat
31
What kit would you recommend? Since ST and KWv1s are basically the same.
      04-10-2018, 12:43 AM   #11
Blueeyesredpanda
401
Drives: E90 / F30
Off topic, comparing both, I would get ST and spray few layers of protection coat to prevent rust.
Back to the topic, I would not get either.
eetadik22.50
      04-10-2018, 12:46 AM   #12
HooDat
31
haha yeah, since they are basically the same but different material. I also heard FA500s and BC BR Coilovers may be just repackaged/rebranded coilovers. Not sure if this is confirmed.
It's just annoying that the one's with damping adjustment require modification for the struts.
      04-10-2018, 01:18 AM   #13
Blueeyesredpanda
401
Drives: E90 / F30
      04-10-2018, 01:20 AM   #14
Blueeyesredpanda
401
Drives: E90 / F30
Repackaged coilovers of what brands? I have heard of FA500 are repackaged too, but I dont think BC is because they are a pretty big coilover company. Meanwhile, ISC and Godspeed looks like its REP of some brand
      04-10-2018, 04:18 PM   #15
eetadik
23
Drives: Noneya
FA500's are excellent and have a great set of features, BC Racing seems to have some really good feedback and I hear their customer service is top notch - something nice to have with an aftermarket suspension. KW's are solid but I still feel that they lack in certain areas where BC and the like really shine. ISC is another company that I have heard some good things about, really good feature set, quality dampers and the ability to run Swift Springs as well (Fortune and BC offer this as well). Me personally...Id go with the FA500's myself. 8k front 12k rear with Swifts if I had my druthers...
      04-10-2018, 07:18 PM   #16
Blueeyesredpanda
401
Drives: E90 / F30
Thank you for your very helpful information from another thread, I added the 328i xdrive spring rate to this thread
      04-11-2018, 09:42 AM   #17
eetadik
23
Drives: Noneya
Anytime, glad I could help out. Some great info you're getting and it will be nice to have it all in one place as a comprehensive comparison like that!
      04-12-2018, 09:31 AM   #18
N54th
Drives: 335i xdrive
I'm in the market for a set of coilovers since my rear shocks are leaking. For me, it's between BC and FA. I'm leaning more towards BC with swift springs; seems to be the best bang for buck. ~$1300 compared to ~$1600.
      04-13-2018, 03:27 PM   #19
Blueeyesredpanda
401
Drives: E90 / F30
How does swift springs compare to the sets that come with BC? Is it just custom spring rate?
      05-11-2018, 10:03 AM   #20
N54th
Drives: 335i xdrive
They are supposed to valve it for whatever spring rate you specify. With FA and BC, you can order them with custom spring rates but FA you can also order it with Swift springs for the front and rear. BC you only have the option of just the rear for Swift springs which is I'm kind of bummed about but at least you can still choose your spring rates.
      05-15-2018, 02:48 PM   #21
N54th
Drives: 335i xdrive
Add Silvers NEOMAX to this list.
      05-15-2018, 03:21 PM   #22
Blueeyesredpanda
401
Drives: E90 / F30
