04-06-2018, 03:35 PM | #1 |
155
Rep 154
AutoExpress : F90 M5 vs E63S
This weeks edition
https://www.pressreader.com/uk/auto-express/20180405 Verdict 1. M5 THE M5 is faster and more comfortable than the E 63. It’s also as good to drive and offers a great level of tech, so while its character is a little more subtle than the AMG, its spread of ability is actually broader, by the slimmest of margins. It’s practical enough and, although efficiency isn’t as important with cars like these, it’ll be slightly cheaper to run, which is a bonus. 2. E63S IF you’re after real charisma, the E 63 S is brimming with it. It’s as fast as you’ll ever need, handles superbly, offers lovely balance, impressive practicality and an addictive noise. But the M5 is just a little bit better in key areas: it’s marginally faster, the ride is noticeably better and it’s more comfortable and refined. Still, personal choice will play a big part here; both are brilliant.
F83 M4 Convertible, Austin Yellow
Previous BMW Cars 2012, E93 335i 2009, E92 335i 2005, E90 325i |
04-06-2018, 04:01 PM | #3 |
155
Rep 154
Yes they have
M5 vs E63S 0-60mph 3.2 vs 3.3 sec 30-70mph 2.3 vs 2.5 sec 30-50mph in 3rd/4th 1.5/2.0 sec vs 1.6/2.2 sec 50-70mph in 5th/6th/7th/8th 2.4/3.3/4.2/7.6 sec vs 2.5/3.4/4.8/7.8
04-06-2018, 04:48 PM | #5 |
3618
Rep 4,532
04-06-2018, 06:55 PM | #6 | |
967
Rep 1,080
04-06-2018, 11:52 PM | #8 |
155
Rep 154
M5 – Driving Impressions
THE M5 proves that it’s devastatingly effective with four-wheel drive. That engine produces 592bhp and 750Nm of torque, so the traction the M xdrive system brings is welcome – but it’s the calibration for the M5 that’s a stroke of genius. Combined with the Active M diff, in 4WD Sport mode the agility belies the M5’s size and weight. It still feels large, but the car behaves like a nicely balanced rear-drive sports saloon, with the diff helping to turn the BMW when you get on the throttle. The M xdrive system then diverts more power to the front when you need it to drag the car out of a corner with plenty of stability and at an alarming speed. It’s a shame the steering’s squishy, slightly resistive feel to your inputs removes a layer of communication and means you’re not all that well connected to the front tyres, but the security four-wheel drive brings is unmatched. As is the pace. The M5 sprinted from 0-60mph in an incredible 3.2 seconds – one tenth faster than the 100kg heavier E 63 S. However, you’ll be hard pushed to notice this or the M5’s in-gear advantage over the AMG, which was around a tenth or two in most ratios. What you will notice is the noise. Both V8s’ sound signatures are electronically enhanced, but the M5’s engine is more synthesised. With the £1,100 M Sport exhaust activated it produces a flat bark as the motor ramps up to 7,000rpm, but lift off and it drones artificially. It can’t match the AMG’S personality. The gearbox doesn’t have the snap of the old DCT, but the shifts are smooth. It backs this up with plusher suspension damping than the E 63’s. In Comfort it’s more compliant, softening blows and smothering bumps with more refinement and composure than the firmer-feeling Mercedes. It’s a more refined car, yet in the raciest modes the BMW matches its body control and delivers lots of grip; we’d just like more communicative steering. E63S Driving Impressions THAT incredible V8 defines the E 63 S and gives it an addictive personality. While it was one tenth slower than the M5 from 0-60mph in our tests, taking 3.3 seconds, this is still incredibly rapid for a near-two-tonne supersaloon. The motor feels even more explosive than the BMW’S and romps from low revs, rocketing through the mid-range and hammering towards its rev limiter with an incredibly bassy but rich and purposeful soundtrack, popping and banging with that AMG exhaust engaged. The shifts are a match for the M5’s in manual mode, while it’s as smooth in Comfort and therefore as easy to drive as the BMW. It has nicer steering that delivers more feedback than the M5, without its squidgy and indistinct feel; as you move off centre the weightier set-up in the E 63 feels more natural. Adding weight to the M5 with its different modes makes it even more artificial. There’s lots of grip to exploit, but the AMG is much firmer than the M car, even in its Comfort setting. On 20-inch alloys – standard on the E 63 S – it thumps over potholes and expansion strips, while even smaller ridges and inputs to the suspension unsettle the car more than in the BMW. The tighter focus means body control is good, but the road noise from the big wheels and tyres isn’t suppressed as well as in the BMW. Toggle through to Sport+ mode for the dampers and the E 63 ramps up control, with a more rigid feeling. It’s surprising just how hard you can lean on the chassis and how well it stands up to this punishment, but as with the M5, its size means it’s better suited to more open B-roads and A-roads, where the 4WD system can work to enhance agility.
04-07-2018, 05:06 AM | #9 | |
14
Rep 70
https://www.youtube.com/watch?v=DdBT0DRC21Y |
04-07-2018, 05:11 AM | #10 | |
194
Rep 850
04-07-2018, 08:14 AM | #12 | |
3618
Rep 4,532
Actual data is YOUR ENEMY WEAKSAUCE ! Google “AMG Character “......and you’ll feel better. Plus, keep repeating to yourself “BMW is bribing everyone....it can’t be true “. |
04-07-2018, 08:44 AM | #13 |
410
Rep 510
Interesting comparo. Apparently M and AMG keep playing to their strengths.
BMW M - refinement AMG - character. It has been like this since the W204 vs E90 and apparently the trend will continue. Nevertheless I expected to hear that the F90 had more agility and stability with better steering feel, but that was not really the case. Good showing by both brands. The E63 is receiving a LCI this year (very early on, which is unusual and Comp Pack is coming out for the M5). |
04-07-2018, 01:02 PM | #14 | |
2872
Rep 7,885
Bottom line, F90 M5 is the more athletic of the two but not by much. The E63S is more of a brute force machine and sounds like it too. Unless you are going to be canyon carving on a weekly basis to really enjoy the weight advantage the F90 offers, the E63S provides more "fun factor" for every day driving situations. Although in terms of comfort the F90 is definitely the winner for every day driving, as the seats are far superior than the standard seats in the E63S, while the racing seats option in the E63S are not really comfortable for long periods of driving in that car. The E63S offers more sleeper status as well, as I honestly cannot tell the difference between it and a C63S sedan in random traffic. These two are so close now they are almost indistinguishable. I only choose the E63S over the F90 because of the lack of innovation when it came to the engine choice for the F90. I'm hoping the next generation G90 M5 will not feature an S63xx version again, then I will be excited once more for the new M5.
04-07-2018, 02:02 PM | #15 | |
410
Rep 510
04-07-2018, 05:32 PM | #16 |
194
Rep 850
From my reading of the article, it is the sound of the E63S engine that makes it "feel"better; not that the engine performance is better.
04-07-2018, 05:41 PM | #17 |
194
Rep 850
As for steering feel there are reviewers with different view...
"he latest E63 S is a very fine piece of kit, but in certain areas it is not quite as well honed as the new M5. One important point in favour of the BMW is its steering. The variable-effort rack operates with commendable precision, balance and agility. Steering angle and steering effort work in total harmony, even when you start changing the settings named Comfort, Sport and Sport Plus. The Mercedes’ steering feels meaty and switched on, but the self-centring motion is somewhat exaggerated. In addition, it takes a more conscious turn at the wheel to dial in lock. Wind on more, and the feedback starts to blur just a touch. When the tail eventually swings round, the steering response is quite light until you reach the point when an invisible counterweight tells the palms in no unclear terms that the next move may be Game Over. In certain situations this system just feels too clever for its own good, where the direction-finder of the M5 is more linear, and its response has more depth." https://www.google.com.sg/amp/s/www....n-test-review/ |
04-07-2018, 10:49 PM | #18 | |
751
Rep 1,857
04-09-2018, 07:22 PM | #19 |
147
Rep 389
If I did not already have a f10 550i M-Sport with extras, then the f90 M5 might look more exciting. I am just ready for a change. It will be either the M5 or E63s and so far I am leaning AMG... .
Agreed that the reviews are following a pattern, with performance trading off in many reviews. Seems even performance but the M5 can go more comfy (a good quality). |
04-10-2018, 08:44 AM | #20 | |
168
Rep 454
04-10-2018, 01:43 PM | #21 | |
147
Rep 389
Well, this is probably why they make different makes and models of cars--everyone can get what they like! As far as grill and other similarities among different models, welcome to Audi, BMW and Mercedes. The f90 and f10 550i M-Sport (and even lower models with M-Sport Packages) look frighteningly similar to the f90 M5 both inside and out. The M5 of course has many actual material differences and is a better performance car in all respects. I feel fortunate that we are at a time when we have several excellent choices--not sure how long that will last with green cars, earth-huggers, etc. Time will tell. |
04-10-2018, 02:52 PM | #22 | |
168
Rep 454
