04-05-2018, 04:36 PM | #1 |
BMW obsessed
9548
Rep 10,844
IND | F90 M5 Painted Trunk Emblem | Installation Procedure
Step 1: Apply a solid border of painters tape around the trunk emblem to create a barrier between the paint and factory unit. This will also aid your placement of the IND emblem. Step 2: Use the supplied piece of fishing line to work your way under each piece of the trunk emblem. Step 3: Remove the excess residue from the trunk to ensure a smooth paint surface onto which the IND replacement can adhere. You can use a combination of adhesive remover and a light duty polish for a finishing touch. Step 4: Peel the IND replacement trunk emblem from the backing paper and carefully align each piece individually with your painters tape guideline. With uniform pressure, press the emblem down to ensure proper adhesion. Step 5: Once the emblem is secured, remove the painters tape surround.
