04-04-2018, 11:41 AM | #1 |
Rep 7
F30 328xi Sports+ Coding
I'd like to code sports+ mode onto my 2014 328xi, would this be possible? I currently have eco pro, comfort, and sport, but I'd like to have sports mode and DSC off at the same time. I found this info in an old thread:
Do the following: Kombi => 300C ECO_FDS =>Function FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv ICM/IcmKod_B_S2TBA -> verbaut It will activate sport+ and sport transmission ))) Or you also could add 2TB option and delete 205 in salapa element When I go into sports mode and switch to manual my cluster reads "S1, S2, S3...", does this mean I have SAT already? I do not have paddles so what would I need to code in order to have sports+ available in the menu and also not have the car outputting any errors? I was going to use bimmercode unless something else would be better for this. Also, what's the difference between 2TB and 205? Thanks in advance for any help |
04-04-2018, 01:30 PM | #2 | |
16
Rep 144
04-04-2018, 03:27 PM | #3 |
Rep 7
04-04-2018, 06:21 PM | #4 |
16
Rep 144
04-04-2018, 09:49 PM | #5 |
Rep 7
If all it takes is changing the values I put in my original post is what it takes, I'm sure I can manage. But I believe some of that code is for paddle shifters and I don't want the car outputting errors, do you know which are for the paddles?
04-04-2018, 10:45 PM | #6 |
16
Rep 144
Sorry unfortunately I don't however, there are plenty more threads and posts on SAT/Sport+ coding, I'm sure they'll be able to help you out
04-04-2018, 11:43 PM | #7 | |
140
Rep 216
Drives: F30 335i PWG
04-04-2018, 11:51 PM | #8 |
Rep 7
Thanks for the info my OBD adapter is coming soon- what exactly is the difference between 2TB and 205? And also what is VO and how do I check it? Also I just checked my VIN, i have 205, however it shows s1, s2, s3 when i go to manual mode. I was reading online that 2TB is paddle shifters. Won't the car output errors if I put on 2TB because I don't have the hardware for it?
04-05-2018, 12:28 AM | #9 | |
140
Rep 216
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
04-05-2018, 12:29 AM | #10 | |
Rep 7
04-05-2018, 12:37 AM | #11 | ||
140
Rep 216
04-05-2018, 12:40 AM | #12 |
Rep 7
Gotcha, so there is VO coding and FDL coding right? Do you recommend a specific app or program that can VO code? I'm open to use anything
