04-02-2018, 02:49 PM | #1 |
BMW obsessed
9580
Rep 10,875
IND | F90 M5 Painted Trunk Roundel | Installation Procedure
Step 1: Apply a solid ring of painters rape around the trunk roundel to create a barrier between the paint and factory unit. Step 2: Use the supplied piece of fishing line to work your way around the circumference of the roundel. This will break the adhesion of the double sided tape that secures the roundel. Step 3: Carefully pull up the roundel to release it from the retaining tabs. You may use a bondo spreader to help pop it free. Keep the factory grommets in place to re-use them. Step 4: Clean the residue from the OE double-side tape with a clean cloth and adhesive remover. Ensure the area is clean and dry before installing the IND hood roundel. Step 5: After discarding the ring of painters tape from the hood, expose the double-sided tape on the IND roundel and, with uniform pressure, press the new piece into place.
