White Smoke
03-28-2018, 08:43 PM | #1 |
23
Rep 133
White Smoke
Recently tuned and deleted. I'm now getting a rather large cloud of white smoke on the first acceleration after idling for a little while. If I'm waiting for a long time at a light or leave it idling for a while I get a rather large cloud of whitish smoke on acceleration (not limited to WOT). It seems to clear up quite quickly and I don't notice it when driving or after a short stop. It seems to have gotten worse in the last couple of weeks. No codes (and yes my codes still work). I would have to assume it's oil burning. If it's oil I would guess CCV or valve cover gasket (highly doubt turbo seals). My first guess would be CCV and potentially oil pooling in intercooler and the acceleration (and boost) blows it into the intake at once? How would I go about checking this theory? Any other ideas?
03-28-2018, 10:16 PM | #2 |
23
Rep 133
https://youtu.be/_tiCMywSF5s
So it was dark when I got around to doing this but it will give you an idea of the quantity of smoke. I'll try to get a similar video tomorrow in the daylight. |
03-30-2018, 08:55 AM | #3 |
614
Rep 2,410
Here's a couple links that might help (there's also threads on here with discussions on various forms of smoke). Based on having full deletes and what you're describing and the ambient conditions and your short video, I'm not sure it's actually a "problem"...
https://www.hotshotsecret.com/reading-exhaust-smoke/ https://costeffective.com.au/2017/03...s-you-a-story/ Here's a thread from 335dsleeper regarding a valve cover replacement helping a "smoke" problem, but it seems to be different characteristics than what you are describing. http://www.e90post.com/forums/showthread.php?t=1456308
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
04-25-2018, 07:56 AM | #4 | |
109
Rep 934
04-26-2018, 09:16 AM | #5 |
BRR tuned
220
Rep 646
does it do this only when the motor is cold, or does it do the same thing after you drive for along time all the time?
To check to see if the CCV is leaking pull the tube off the intake pipe and plug the hole on the intake.. drive around and see if it stops it would probably be best to run a tube into a well vented bottle and that way you could see how much oil is coming out the CCV at the same time.. valve cover gaskets tend to leak more under boost conditions if i remember right... almost sounds like a valve seal is bad... |
04-26-2018, 06:35 PM | #6 |
23
Rep 133
So I replaced the valve cover gasket but I haven't driven it much. Right now it's at the dealer for FRM. My valve cover gasket was in terrible shape and it appears that oil was leaking down the side of the motor. I've put less than 20 miles on it since, but I was still getting some white smoke. I hope it's just oil that was left in the intercooler. Hopefully this next week I will be able to put some miles on and see if the smoke goes away.
As to the conditions that would cause smoke, it started smoking a little at idle. On acceleration after idling the amount of smoke increased to a large plume. Much more than in the video. I didn't notice smoke while driving, but I assume there was some smoke there too. It also started leaking oil. |
04-27-2018, 03:06 PM | #8 | |
23
Rep 133
I didn't notice any more oil leaking, so I think the valve cover was indeed bad. If the smoke doesn't clear up it may be a bad CCV system or turbo seals. Hoping it's not a turbo at this point (in a year or 2 I would like a reason to upgrade). |
05-25-2018, 07:08 PM | #10 |
23
Rep 133
Another follow-up. The white smoke is now gone without any other changes. I noticed it become much worse after treating with diesel extreme. I've since a full tank after the diesel extreme (with EDT) and the smoke just disappeared one day. My best guess is that the white smoke was unburned fuel caused by a sticking or piddling injector. My rings must still be pretty good as I didn't notice a rising oil level. I will do an oil analysis to determine the amount of dilution.
I think the fuel treatment was both the cause of and solution to my problem. I would guess that during the cleaning process it got worse before it got better. Next time I treat with diesel extreme I will post back if the same thing happens again. Just glad I didn't spend $43 per injector getting them tested when there doesn't seem to be a long term problem. |
05-27-2018, 08:57 AM | #11 |
54
Rep 238
When I upgraded my IC to the ATM at 65k I drained out about 8oz of oil in the factory IC. That problem should be nearline solved with the catch can installation.
What is your current mileage on the vehicle? I would probably do another extreme dose at the 5-6k mark to give the injectors another cleaning. In a similar note I am halfway through a tank of extreme on a VW tdi I just dosed at 170k. |
