03-28-2018, 03:39 AM | #1 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Schroth QuickFit harness install Qs
I have a few install questions on the Schroth QuickFit harnesses, and I wanted to share something I learned as well.
And now the interesting bit I discovered... the Schroth Quickfit for VW/Audi seems to be identical to the one they sell for E92 BMW (which I believe is the "right" set to use for our car). My Schroth belt set from my 2012 TT clips in securely and fully to the BMW receptacles.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
03-28-2018, 09:26 AM | #2 |
518
Rep 582
I use these belts in my car. Standard bolts hold on the OEM belts in place. They may be the star pattern rather than hex, I can't recall exactly. The rear seat is just clipped in. Pull up and out.
I'm not sure on the torque specs, maybe someone else can help out with that.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
ZPrime611.50 |
03-28-2018, 04:15 PM | #3 |
375
Rep 426
Here you can find the required torque infos. It's 42 Nm.
ZPrime611.50 |
03-28-2018, 06:15 PM | #4 | |
I INDIC8
612
Rep 1,286
From the picture it looks like it may be a female torx head / male torx driver bit.
03-29-2018, 07:56 AM | #5 |
2088
Rep 3,006
1. Yes, torx
2. Tano provided 3. All BMW rear seats, lift up from front middle edge I reused the bolt and now that you mention it will go back and add some blue loctite. A lot of BMW procedures recommend replacing bolts, e.g. suspension. Some think it's overkill others just follow the instructions. I replaced some parts on my X5 suspension and ended up replacing all of the bolt b/c my friend insisted that I should and they were parts that are not replaced very often (~80k miles or greater) and only costed me $30 or so extra to do. Though I always replace nylock nuts. |
03-29-2018, 08:32 AM | #6 |
Rep 13
I spoke with HMS Motorsports and they said it was "not approved" for the M2 because they have not done a sled test to confirm the seat will handle the g-load in an accident. Is this just them cya in case something goes wrong or is this legitimate?
2017 LBB M2 MT
harkes1077.00 |
03-29-2018, 08:51 AM | #7 |
2088
Rep 3,006
I also spoke w/them and they stated the same and instead recommended the rallye, which are a generic set for "all" cars.
If you compare the installation instruction constraints, I think your question will be answered. http://f87.bimmerpost.com/forums/sho....php?t=1392715 http://f87.bimmerpost.com/forums/sho....php?t=1355999 Last edited by omasou; 03-29-2018 at 08:56 AM.. |
03-29-2018, 06:04 PM | #8 |
I INDIC8
612
Rep 1,286
I'd say it's a CYA...
07-24-2023, 08:27 PM | #9 |
120
Rep 217
One of the concerns I've heard about running the E92 QFP in an F87 is that the angle of the tail straps is different and could lead to spinal compression. I own both an E92 and an F87 so I just measured and compared the angle in both. My approach on the driver's side was to tie a string to the rear female seat buckle and run it to the right side post on the headrest. I put both seats in my "track position". The angle of the string on each was exactly the same: 46 degrees.
The strength of the seatback is still an unknown without a sled test, but at least we can put the angle question to rest.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" |
07-25-2023, 03:13 AM | #10 |
M///modifyer
2489
Rep 1,295
Not sure where you are located or what Motorsport you are competing in but a harness is not a safe option with a 2 piece seat & not allowed in various Motorsport disciplines.
Yes there is a Schroth vehicle specific harness designed for club level track day use, however a harness with a 2 piece seat is generally never a good idea due to the inherent dangers of the backrest collapsing. A minimum 45+ degrees taper is fine & due to the length the belts should be crossed over between the seat & rear mounting points. (My RS200 tarmac rally car & my M2 road/track car below for reference).
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 Last edited by TargaM2; 07-25-2023 at 03:48 AM.. |
07-25-2023, 06:38 PM | #11 | |
120
Rep 217
https://www.schrothracing.com/item/s...-quickfit-pro/
07-25-2023, 10:06 PM | #12 | |
M///modifyer
2489
Rep 1,295
Everything I said still applies, if you want to use a harness on track which is obviously advisable then you should also be using a 1 piece seat.
Best Modified BMW - BMW Nationals 2022 |
07-27-2023, 02:55 AM | #13 | |
437
Rep 553
Schroth Quickfit. Fitment in our car is identical to the e series so while Schroth won't 'approve' use in the F87 there is no reason to believe it would perform any differently. The 2nd point about using it with a 2 piece seat should really be a comparison against the oem 3 point lap/sash belt. If you have a 1 piece seat then safety obviously dictates you should have at minimum a half cage in which case you then have mounting points for a normal harness so no need for a Quickfit. With ASM tech the Quickfit works/restrains similar to a lap/sash, except for a catastrophic rollover where you may be held more upright than a lap/sash I'm not sure there would be any circumstance where you would be worse off with the Quickfit over a lap/sash? If anyone has seen the video of the F22 crashing on a UK trackday when it rolls over I'd say 5-8 times (hard to see for all the dust) it's surprising how well the roof withstands all the impacts. |
fleetfoot120.00 |
07-27-2023, 04:03 AM | #14 | |
M///modifyer
2489
Rep 1,295
You can assume all you like about the quickfit/F87 compatibility & i understand the frustration but unfortunately the fact is its not approved for use in the F87. Your 2nd point about safety “obviously” dictating you require a cage when using a harness is absolute rubbish. A 1 piece seat & correctly fitted harness is the safest/best track option regardless of whether you are using a cage or not (obviously a cage offers an additional benefit & is required when progressing to higher levels of competition). As a national level scrutineer for the past couple of decades & competition car builder/competitor for even longer I can assure you many cars can be & are fitted with a 6 point harness & 1 piece seat safely/correctly without using a cage, if you don’t know how that’s just ignorance not factual.
07-27-2023, 05:15 AM | #15 | |
437
Rep 553
I'm genuinely curious though about a harness/1 piece seat, are you saying use of these is considered safe without any re-enforced overhead structure in case of roll-over? (ie solely relying on integrity of the oem pillars/roof structure) |
07-27-2023, 06:08 AM | #16 | |
M///modifyer
2489
Rep 1,295
No of course I’m not saying any seat/harness combo is safe in a rollover, obviously a cage is required for any form of r-o-p. Please go to the “Motorsport Australia” website for any safety related information, a forum is not the right place to enquire about such things, especially an international forum as all countries have very different regulations.
07-27-2023, 06:40 AM | #17 | |
437
Rep 553
The MA website will only say what's required/approved, won't help with explanatory notes/supporting docs. Why isn't a Forum a place to discuss safety? Some informed comment accompanied by supporting evidence would surely be of benefit to all |
07-27-2023, 06:44 AM | #18 |
120
Rep 217
TargaM2 I have a hypothetical situation that might help us draw on the wealth of knowledge and experience you have: if I were (hypothetically) to hire you as a driving coach, and you had the choice of instructing me in my E92 with 4-point QFP harnesses and no roll cage OR my F87 with the OEM 3-points, which car would you prefer to ride in for your own personal safety? For simplicity, let's assume you're wearing a Simpson Hybrid-S and the cars will be limited to the same max speeds.
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" Last edited by fleetfoot; 07-27-2023 at 06:53 AM.. |
07-29-2023, 09:16 PM | #19 | |
437
Rep 553
Plse correct me if I'm reading this wrong https://www.motorsport.org.au/docs/d...sn=4e2f976e_14 |
07-30-2023, 07:03 AM | #20 |
1120
Rep 1,644
Here are the facts: the Quickfit harness is not approved for the F87 because they have not tested the F87 seats. If you want to assume they are equal or stronger than e82 seats go for it, but there is zero test evidence of that. Also, none of Schroth testing for ASM or their quick fit harness setup is to any kind of approved industry standard. They made up the test parameters themselves.
That being said, it’s really more of a personal risk decision. |
07-30-2023, 08:12 AM | #21 | |
437
Rep 553
Of course it's possible BMW went to a weaker seat back structure in the F series but without evidence of that it surely is reasonable and the most likely case that the F seat is equal or better. Schroth's testing I imagine is consistent with the type of testing accepted in the industry otherwise imagine the financial risk (ie litigation) they are exposed to in 'approving' the Quickfit/Pro for fitment as they prescribe. Ultimately as you say it's personal choice, for a road registered car without a cage & using a 3/4 point harness I'd much rather have the Schroth with ASM & oem seat. |
07-30-2023, 04:02 PM | #22 |
120
Rep 217
It looks like I'm not going to get a response to my hypothetical question above, so I decided to take ChatGPT for a spin (no pun intended). Obviously I have zero trust in ChatGPT as a safety expert, but I thought the response was well thought out and interesting, so I'll share here:
Given the hypothetical safety situation and the choice between the two cars, as a safety-conscious driving coach with extensive experience, I would prefer to ride in the 2013 E92 BMW 328i with 4-point Schroth QuickFit Pro harnesses. The reason for this choice is that the 4-point harness provides a superior level of occupant restraint compared to the OEM 3-point seatbelts in the 2017 F87 BMW M2. The 4-point harness will help keep you securely in place during high-speed maneuvers and in the event of sudden braking or cornering forces. This added restraint minimizes the risk of injury and increases the chances of staying properly positioned in the seat, which is crucial for maintaining control of the vehicle. The 2017 BMW M2 may be a more powerful and performance-oriented car, but without a roll cage, the 4-point harness in the 2013 BMW 328i offers better safety features for track driving. A roll cage can significantly enhance the safety of a vehicle by providing additional protection in case of a rollover, but since neither car has a roll cage, the choice remains between the seatbelt systems. To maximize personal safety, a combination of a 4-point harness and a Simpson Hybrid-S device would be the preferred setup for a driving coach like myself. The Hybrid-S provides additional head and neck protection, reducing the risk of injury in the event of sudden deceleration or impact. Remember, safety should always be the top priority when engaging in motorsport activities. The equipment and restraints used can make a significant difference in potential outcomes in case of an accident. |
