M Performance Steering Wheel + JB4
03-22-2018, 03:10 PM | #1 |
Meowster
50
Rep 57
Is anyone here running the M Performance Steering Wheel(LED's) with JB4? I've heard many things but no one can give me a straight answer. Even contacted BMS and asked and they said it should be fine. I'm just wondering if anyone here ACTUALLY has the combo -
04-29-2018, 04:23 PM | #2 | |
Not enough time!
12
Rep 45
So I felt confident enough to try and I just bought one used (V2). I will install in the next week or two. I will let you know after how it goes. My car is a 2010 E90 with JB4 & BEF.
2010 E90 335XI 6AT with XHP stage 3 | JB4 G5 W/Trebila Tune | RB Next Gen 15T | RB hot side INLETs | ETS FMIC | VRSF CP | FORGE DV | Custom METH KIT CM10+CM5 plus MMP gen2 PI | AR design cer. DPs | BMS OCC | RB external PCV w/plugged HEAD. Best 1/4: 11.47@123mph
04-30-2018, 01:21 AM | #3 | |
Meowster
50
Rep 57
04-30-2018, 08:09 PM | #4 | |
Not enough time!
12
Rep 45
I'll keep you updated
ipbln50.00 |
05-27-2018, 09:26 AM | #6 |
Not enough time!
12
Rep 45
I have finally installed the steering V2. I did not had to code anything on the car, on the first power up, everything worked perfectly.
I was wondering if with the JB4 gauge hijack the oil temperature and fuel display would work when the JB4 is in either map0 or other maps; it does work perfectly in any maps. I do drag races with the car so I push really hard and the JB4 is quite solicited and I can report that so far, the steering V2 and the JB4 are compatible together!
ipbln50.00 |
06-23-2019, 10:59 PM | #8 |
27
Rep 144
Frequently, in max load conditions, my steering wheel rpm gets bugged and freezes. Shift lights do not work in relation to rpm when this happens and turn on every time I press the clutch pedal. At first, I thought it was a power issue so I rerouted steering wheel power to the fuse box instead of the CAS, but this did not work.
Just wondering if the CAN signals are affected with steering wheel + jb4? |
