Minus the Purchase Price, how much has your E9X cost you?
03-21-2018, 09:45 PM | #1 |
51
Rep 273
I've had a question that's been on my mind lately, as I've been spotting more and more e90's in my area (near Houston), and I'm just scratching my head, are people not experiencing similar issues I've had, or just buying up these cars maybe because of depreciation, or what? Doesn't seem like the parts price or labor has dropped (or maybe I'm wrong)?
So I was curious to see since owning your E9X, how much have spent towards maintenance? I have a 08 E93 335i (3 yrs ownership so far) and here's a just a overview of something of the issues/things I had to take care of in 3 years. I'm sure there's a grand or two missing from here, but this is just off the top of my head. Also, the car had a ton of work done prior to ownership (HPFP, leaky injectors, transmission leaking, wiring, etc):
03-21-2018, 10:08 PM | #2 |
494
Rep 1,416
2/15/2016 purchase of a 1 owner CPO 2011 335i xDrive with 40k miles (5/2011 build date)
Year One- 2016 - 3/2016 - 43,000 miles $80 oil change at dealership $60 for engine and cabin air filters $120 for brake fluid flush Year Two - 3/2017 - 48,000 miles $585 for four new Continental DWS tires to replace the four OEM original crappy Continental SSR run flats $250 for a rear quarter panel fender dent repaired at BMW dealership $200 for broken and leaking headlamp washer fluid pump at BMW dealership Quoted at BMW dealership $1200 for four new run flat SSR tires. Declined Quoted at BMW dealership $1300 for leaky oil filter housing gasket. Declined Year Three - 3/2018 - 53,000 miles $80 Oil Change at BMW dealership $120 Brake Fluid Flush Quoted at BMW dealership $492 for a new battery. Declined Quoted at BMW dealership $500 for new spark plugs. Declined for the year so far. I will also need new front/rear brakes $500 DIY (or $800+ at dealership) before the year ends or in the next 3,700 miles. I am an exception in the BMW E90 forum because I own two cars and do not drive my BMW everyday. It is parked and garaged in the winter months from December to February (hence why I need a new battery) and casually (weekend) driven the rest of the year. I believe the daily E90 driver will experience a lot more wear and tear spending then myself.
03-21-2018, 11:14 PM | #4 | |
51
Rep 273
03-21-2018, 11:16 PM | #5 |
51
Rep 273
03-21-2018, 11:43 PM | #6 | |
Art Collector
2427
Rep 3,450
I only paid $3k CAD for the car so I'm happy overall! Just one previous owner, and he maintained it exceptionally well... all dealer serviced, and brand new brakes a few months prior to me buying it. I'll be doing a PS pump in a couple weeks too, but with a used part. Current pump is groaning. So that'll add about $150 to my tab. Diff pinion seal was leaking... That's the extent of it as far as I know. The torque converter is also sweating a bit, but nothing major. Oil pan is leaking (minor) but it isn't the gasket, which was done a couple years ago. Fixing it will likely entail replacing whole pan. Thanks but no thanks, haha... In the end, it's really all worthwhile when I get into it and drive. |
03-22-2018, 12:44 AM | #7 |
2191
Rep 5,007
Year 1 - 60k miles
- $120 Tensioner/pulley - $3x windshield moulding - $48 oil change - $540 trans fluid change (opted to do this @60k miles) - $70 air filter + cabin Filter Year 2 - 73k miles - $48 oil change - $2x rear tail light seal - $7 rearview mirror glue - $175 (?) Rear brake rotors and all 4 pads Year 3 - currently 84k miles - $48 oil change - $14 wiper blades (front only) Oddities of my ownership - I change the oil @5k -7.5k based on the fact that the car sees a lot of cold starts in hilly San Francisco. Basically, I feel bad for the car. You should see when my wife pulls away on a cold start - zero f*cks given. I also did the trans fluid that likely wasn't needed, but I am hoping to own this car for an extended period so I'm trying to maximize the transmission life. It's the only job I've paid to have done on the car. Last edited by tlow98; 03-22-2018 at 12:49 AM.. |
03-22-2018, 12:56 AM | #8 |
Curmudgeon and Pedant
690
Rep 3,489
Excluding tires, $13282 for my 2010 335d with 127000 miles. It would have been $4500 higher except BMWNA stepped up with 12/120K warranties on the DEF tank and NOx sensors.
03-22-2018, 01:20 AM | #9 |
41
Rep 108
E90 328xi @ 170k km.. for the past 45k km I have replaced (canadian prices)
Rear Wheel Bearings $120 parts + $150 labour Rear Shocks $120 parts + self labour 4 Tires to Continental ExtrCont DWS06 $850 parts + $90 labour BMW Style 197 Rims $420 for the set Oil Change x5 $60 per change with filter etc. = $300 + self labour Coolant Flush $25 + self labour Cabin/Engine Filter Change $40 + self labour Spark Plugs $65 parts + self labour Power Steering Flush $25 + self labour Fuel (91 Shell V-Power) = $5745 so far Grand total (excluding fuel)= $2205.. considering that tires/wheels were an upgrade then it'd be $845 Need to change in the future Control Arm Bushings for the front Find the culprit for slow coolant leak in one my hoses Transmission/Diff/Transfer Case Flush |
03-22-2018, 01:45 AM | #10 |
2191
Rep 5,007
03-22-2018, 03:06 AM | #11 |
38
Rep 111
My car: 2011 BMW E90 325i MSport
year 1 55k miles 490£ - clutch kit. advised by an independent garage I took my car to to check on a whining noise only on 2nd gear at low rpms. The sound was still there, old clutch was clearly in perfect condition. Got my money back from my warranty and a free Service and MOT to make up for their mistake. 500£ new tyres 13£ driver side headlight light bulb 1.5 year - 69k miles 1350£ - spark plugs, coils and Nox sensor. Car is misfiring. Changing these didn't fixed the issue. Car is going to BMW dealership next Monday for diagnostic and investigation. Close future - 125£ diagnostic and investigation for my misfires at BMW and then fixing whatever the issue is at an independent BMW garage. |
03-22-2018, 08:40 AM | #12 | |
52
Rep 471
-Kevin |
03-22-2018, 08:47 AM | #13 |
51
Rep 273
That was once a year since I drove less than 8k miles. The dealer charged around $110 for the first two, and then I did my own two months ago. $80 for the oil and filter, and add another $20-$30 for oil filter cap, 17mm socket, oil drain container to pour old oil, and misc expenses like gloves and shop towels.
Of course I expect the cost to be less, and since the dealer spotted a leaky gasket, im guess they might replace the eccentric shaft and do another oil change? |
03-22-2018, 09:24 AM | #14 |
494
Rep 1,416
I was thinking the same. $330 for an oil change is excessive!
03-22-2018, 10:18 AM | #16 | |
Art Collector
2427
Rep 3,450
Alright, so I'm not looking to open up a debate about oil brands, but what are you using that you've done changes for $60 filter included? I'm interested in this. |
03-22-2018, 10:24 AM | #17 |
52
Rep 471
03-22-2018, 10:43 AM | #19 |
3540
Rep 3,052
I've only owned my E92 for 20 months and average $67 a month. That is for maintenance and replacing plastic bits that deteriorated or broke. I will be doing the OFHG and VCG this summer and would like to upgrade to a set of Style 437's, so I'm sure that number will go up. It's much better than the $110 average that the E46 required and I hope that I shopped smarter on this car.
03-22-2018, 10:52 AM | #20 |
51
Rep 273
03-22-2018, 10:55 AM | #21 | |
51
Rep 273
So 7x bottles of oil at $10 each ($70 + filter) I know, could have got it cheaper (the oil), but I ordered it from a great company online, good service. Last edited by BMWMusician; 03-22-2018 at 11:05 AM.. |
03-22-2018, 12:09 PM | #22 |
682
Rep 1,155
just under $13k in two years. im actually very glad I don't have the car anymore cause it was a legit addiction. only around $1500 of that was maintenance.
